check device attributes always show inorrect in telnet and local
The check device attributes always show 'incorrect' the telnet and local user fields. The device is configured with aaa using tacacs+ and local. Telnet password and local username and password were input correctly both in the device and the check device attributes fields.
Any idea why this happens?
Thanks....
Re: check device attributes always show inorrect in telnet and l
Hai,
I also experiencing the same problem.
But this could help u.
Instead of going to Check Device credential report, got to Device troubleshooting-> device center->select the appropriate device -> select Credential verification report.
This should give u the actual report.
Alternatively u can perform the check immediately by selecting the Management station to Device from Tools section(in same device center page) and check all and give the correct SNMP read and write community - telnet username and password will be taken from the DCR and click ok.
This will give the current status.
Try this. Hope it will be useful information if so please rate it :)
Visvwanathan123,
Thanks for your help.
How do you go to Device troubleshooting? I cannot locate it any folder.
The server is CiscoWorks2000, RME 3.4.
123
