Choose between Cisco SDM Express and Cisco SDM
When two application: Cisco SDM Express and Cisco SDM are installed on the Router flash, how to explicitly choose one or another from the PC Web Browser ?
Example.
I have configured Cisco 877 Router to use SDM.
When I connect to Router from my Web Browser (http://<ip-Address.), SDM Express application is running.
After that I installed full SDM 2.4 version from SDM CD.
Now, when I connect to the Router from PC, full SDM application is running.
But how to choose, if sometimes I would like to run SDM Express application.
Best Regards,
Tomas Chmelevski
1 REPLY
Silver
Re: Choose between Cisco SDM Express and Cisco SDM
Cisco SDM can be used primarily for router and security feature configuration, I think at a time you can run only one SDM so you can manually disable it and use the another one. Otherwise SDM express may be an lower version.
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_user_guide_chapter09186a0080817651.html
143
