Cisco 2960 Temperature OID
I have load CISCO-ENVMON-MIB and initiate walk in it but unable to find OID of Cisco 2960 temperature monitor..
I have search over net and found .1.3.6.1.4.1.9.9.13.1.3.1.3.1 for temperature but this OID is not responding in this mib.
Arshad Ahmed
Re: Cisco 2960 Temperature OID
What is the version of IOS you are using?  What is your SNMP config?
Here is an example output:
snmpwalk -v2c -c public 10.12.12.12 .1.3.6.1.4.1.9.9.13
SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.1 = STRING: "chassis"
SNMPv2-SMI::enterprises.9.9.13.1.3.1.6.1 = INTEGER: 5
SNMPv2-SMI::enterprises.9.9.13.1.4.1.2.1 = STRING: "chassis"
SNMPv2-SMI::enterprises.9.9.13.1.4.1.3.1 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1 = STRING: "internal power supply"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.1 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.1 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.13.1.6.0 = Hex-STRING: 00
SNMPv2-SMI::enterprises.9.9.13.2.1.0 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.2.3.0 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.2.4.0 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.2.5.0 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.2.6.0 = INTEGER: 2
To verify that the MIB exists in your image please navigate to:
http://tools.cisco.com/Support/SNMP/do/MIBSupport.do?local=en&step=3
Once there, issue a 'sh ver' on your device and copy and paste the entire name into the tool.
HI,
I am using cisco 2960 with lan lite image with following features.
Sw Image : C2960-LANLITEK9-M
Model : WS-C2960-24TC-S
Sw Version : 12.2(50)SE4
and the snmp configuration is ..
snmp-server host A:B:C:D version 2c test123
snmp-server enable traps envmon fan shutdown supply temperature status
Arshad Ahmed
6957
