05-30-2010 10:11 PM
I have a Cisco 3945 Router and when we try to add the same into the Cisco Works it gives me an error saying " CM0056 Config fetch failed for 192.168.xx.xx Cause: CM0204 Could not create DeviceContext for 1238 Cause: CM0206 Could not get the config transport implementation for 192.168.xx.xx Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
We are using LMS version 2.6. Please let me know the latest router 3945 with support or not.
Thanks in advance.
Thanks & Regds,
Lalit
Solved! Go to Solution.
05-30-2010 10:20 PM
LMS 2.6 is end of life and end of engineering. Support for new devices is no longer being added. If you require 3900 support, you will need to upgrade to LMS 3.x. An evaluation version of LMS 3.2 can be downloaded from http://www.cisco.com/go/lms. After installing LMS 3.2, you will still need to go to Common Services > Software Center > Device Update, and install all available updates for Common Services and RME.
05-30-2010 10:45 PM
Yes, this version of RME is very old. The current version of RME is 4.3.1. The end of life statement for LMS 2.6 can be found athttp://www.cisco.com/en/US/partner/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_end-of-life_notice0900aecd80532c07.html .
05-30-2010 10:20 PM
05-30-2010 10:32 PM
Hi Joe,
Thanks for the quick reply.The following version we are using :
LMS 2.6 , RME : 4.0.5.
Is this confirm Joe that Older verison will not support new Cisco devices ie 3945 Router.Any documents will be more helpful with regard to the same.
Thanks & Regds,
Lalit
05-30-2010 10:45 PM
05-31-2010 12:23 AM
Hi Joe,
Thanks for the reply and updates.
Thanks & Regds,
Lalit
01-26-2012 01:55 PM
Hi, I am Having same issue, i have LMS 3.0 , what should i do ?:(
CM0056 Config fetch failed for 10.131.0.2 Cause: CM0204 Could not create DeviceContext for 362 Cause: CM0206 Could not get the config transport implementation for 10.131.0.2 Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
01-26-2012 03:24 PM
As I said in this thread, if you have an old version of RME, you need to upgrade to get the latest device packages. You can also perform a Device Package update through LMS (where depends on the version) to get the latest package updates from Cisco.com. If you need more help, please start a new thread and include your version of LMS.
