Cisco 6500 with sup720 booting to rommon
Please how can I solve this problem. This cisco 6500 boots to rommon mode, I can't see any error showing why its booting to rommon.
Hall of Fame Super Silver
From rommon you should be able to direct the switch to boot to the proper image.
Are you able to issue a dir command and see the desired image? Follow the procedure listed here.
Thanks Marvin.
Yes I can see the image on my bootdisk but the swith cannot boot the image even after using the boot
command.
I think the image is corrupted and I don't have another copy of the image anywhere on the switch, no compact flsh.
Is there any other way to load another image?
Appreciate any help please.
You're welcome.
As noted in the linked guide, "If you do not have any copies on either disk0 or disk1 and you encounter the problem of a missing/corrupted image, the only way to recover is to copy the image on the Flash disk from another switch."
Since these supervisors use standard Compact Flash (CF) cards in disk0 or disk1 slots, you can download (and validate the md5 hash) of an IOS image from the cisco.com downlaod section and copy it onto a standard CF card.
Hall of Fame Super Gold
Console into the supervisor card and boot the image.  Post the entire bootup process.  You may not know but it's either your IOS is corrupt or something else.
Here is the boot process:
System Bootstrap, Version 8.5(4)
Copyright (c) 1994-2009 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower memory for cache initialization
Clearing bss
Clearing autoboot state machine
melody_present_reg: 1st read w/ 0x5555
melody_present_reg: 2nd read w/ 0xaaaa, reversed: 0x5555
Bootdisk adapter is detected, enabling bootdisk access...
Reprogramming CS1 w/ Melody value...
Reading monitor variables from NVRAM
Reset reason for CPU board 0xffff , BaseBoard 0x281ffff, display 0x20000System Reset by Software.
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
MOBILE dimm - rev 0.15
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Initializing USB2.0 controller
Exiting init
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
Autoboot: failed, BOOT string is empty
Autoboot executing command: "boot "
Initializing ATA monitor library...
string is bootdisk:s72033-ipbasek9-mz.122-33.SXJ2.bin
Loading image, please wait ...
Stack pointer       : 0x8FFFFF80
monstack            : 0x800FFFC0
monra               : 0xBFC26EC4
edata : 0x80108580
magic : 0xFEEDFACE
memsize             : 0x10000000
uncomp_size         : 0x05090C00
comp_checksum       : 0x98ECBE18
uncomp_checksum     : 0x98ECBE18
CZIP_MEM_BASE       : 0x80000000
_end       : 0x8010BA00
Self extracting the image...
IOS compressed src copy is     : 0x80108594
czip + IOS tar size is :0x00E01FA8
czip + IOS Tar image is now :0x80108794
cptr is now :0x8010BB00
IOS compressed dest copy is     : 0x8010BB00
[OK]
image_entry :0x80100000
__start : 0x80100000
tar_avail_size is now :0x0428EA00
Tar image address is             : 0x80F0DB00
tar_size is           : 0x0428E600
cpu type                   : 0x00000019
image_info.entry_point   = 0x80100000
image_info.section_count = 0x00000005
image_info.monstack      = 0x800FFFC0
image_info.monra         = 0xBFC26EC4
image_info.param0        = 0x00000002
image_info.param1        = 0x00000000
image_info.param2        = 0x800066A8
image_info.param3        = 0x80100000
image_info.reg_k0        = 0x80F0DB00
image_info.reg_k1        = 0x0428E600
Section Index = 0x00000000
    source    = 0x8010BC1C
    dest      = 0x80100000
    bytes     = 0x00010000
Section Index = 0x00000001
    source    = 0x8011BC1C
    dest      = 0x80110000
    bytes     = 0x00000720
Section Index = 0x00000002
    source    = 0x8011C33C
    dest      = 0x80110720
    bytes     = 0x00000020
Section Index = 0x00000003
    source    = 0x8011C35C
    dest      = 0x80110740
    bytes     = 0x00DF1730
Section Index = 0x00000004
    source    = 0x80F0DA8C
    dest      = 0x80F01E70
    bytes     = 0x00000000
reg_v0: 0x00000000
reg_k0: 0x80F0DB00
reg_k1: 0x0428E600
tar_start: 0x00000000
tar_size: 0x00000000
tar size is :0x00B6130E
Tar magic : ustar Tar filename : C2LC memsize             : 0x10000000
Tar gid         : 035231Tar uncomp_size         : 0x00B6130E
Tar mtime         : 11672344432 Tar username          : ccaiTar comp_checksum       : 0x0000125F
Tar group name    : buildTar prefix    : tar_size  in czip         : 0x0428E600
monra               : 0xBFC26EC4
edata : 0x80110740
magic : 0xFEEDFACE
uncomp_size         : 0x02B3E7F0
comp_size           : 0x00DF171C
comp_checksum       : 0xE917F280
uncomp_checksum     : 0xD094D890
Compressed IOS src copy is     : 0x80110754
tar_dest is :0x8BD69200
tar_size is :0x0428E600
Compressed IOS dest copy is     : 0x8AF77AE4
Tar src before IOS decompression is     : 0x80F0DB00
Tar dest before IOS decompression is     : 0x8BD69200
compressed IOS  src is     : 0x8AF77AE4
IOS uncompressed dest copy is     : 0x8013C160
Self decompressing the image : ############################################################################################################################################################################################################################## [OK]
e_shoff :
0x02B3E660
e_flags : 0x10001001
e_phnum :
0x00000001
Source elf_hdr->e_shnum = 0x0000000A
Setting up to copy ELF section 0x00000001
to image_info section 0x00000000
sh_name = 0x0000000B
sh_type = 0x00000001
sh_flags = 0x00000007
sh_addr = 0x80100000
sh_offset = 0x00000060
sh_size = 0x02640000
sh_link = 0x00000000
sh_info = 0x00000000
sh_addralign = 0x00000020
sh_entsize = 0x00000000
Setting up to copy ELF section 0x00000002
to image_info section 0x00000001
sh_name = 0x00000011
sh_flags = 0x00000003
sh_addr = 0x82740000
sh_offset = 0x02640060
sh_size = 0x00373440
sh_addralign = 0x00000008
Setting up to copy ELF section 0x00000003
to image_info section 0x00000002
sh_name = 0x00000017
sh_addr = 0x82AB3440
sh_offset = 0x029B34A0
sh_size = 0x0003EEE4
sh_addralign = 0x00000004
Setting up to copy ELF section 0x00000004
to image_info section 0x00000003
sh_name = 0x00000024
sh_flags = 0x10000003
sh_addr = 0x82AF2324
sh_offset = 0x029F2384
sh_size = 0x0000423C
sh_addralign = 0x00000010
sh_type = 0x00000008
sh_addr = 0x82AF6560
sh_offset = 0x029F65C0
sh_size = 0x00000940
sh_addr = 0x82AF6EA0
sh_size = 0x021FE100
tar file start = 0x84D02F50
image_info.reg_k0        = 0x84D02F50
    source    = 0x8013C1C0
    dest      = 0x80100000
    bytes     = 0x02640000
    source    = 0x8277C1C0
    dest      = 0x8274CFB0
    bytes     = 0x00373440
    source    = 0x82AEF600
    dest      = 0x82AC03F0
    bytes     = 0x0003EEE4
    source    = 0x82B2E4E4
    dest      = 0x82AFF2D4
    bytes     = 0x0000423C
    source    = 0x8BD69200
    dest      = 0x84D02F50
    bytes     = 0x0428E600
data_size  in czip         : 0x00001000
bss end of IOS is         : 0x84D01F50
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, s72033_sp Software (s72033_sp-IPBASEK9-M), Version 12.2(33)SXJ2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 15-Dec-11 01:29 by prod_rel_team
Image text-base: 0x4010132C, data-base: 0x4274CFB0
Active crashed three times, disabling auto-boot and dropping to rommon
Firmware compiled 15-Nov-11 14:23 by integ Build [100]
*Jan  1 02:27:12.643: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch
*Jan  1 02:27:13.459: %PFREDUN-4-SUP_FORCE_TO_ROMMON: Supervisor forced to rommon with reason: Active crashed three times in a row
rommon 1 >
Re: Cisco 6500 with sup720 booting to rommon
Your output shows the reason:
The IOS image is extracting OK - I'd strongly suspect you have a hardware issue with your supervisor. The TAC would be the next step as they would most likely confirm and issue an RMA (assuming you have Smartnet support).
Alright, thanks Leo and Marvin.
You're welcome. Please rate useful answers.
I agree with Marvin.
The switch processor is crashing.  When it handsover to the route process, it crashes too.
When did you start using SXJ2 as an IOS?  There is a very remote possibility that you may not have enough DRAM to load SXJ2.  Again, very, very remote possibility.
I have been able to boot the switch.
What I did was to change the config register to 0x2142, reset then the device went back to rommon mode. I then set the config register back to 0x2102 and  viola!!! the switch boots up.
Now I have restored config to the switch everything seems ok. The only worry I have now is that the SYSTEM LED on the sup engine is showing RED. Does this mean there is a likelihood that the sup engine will fail soon?
I,ve the some problemm with
I,ve the some problemm with my cisco 6503 can i touch contact with you? please? mi email its atejada75 at Hotmail.com
1827
