10-20-2010 01:53 AM
I would like to configure SPAN in one of our Cisco Catalyst 2950 24 switch, but the IOS I downloaded doesn't support SPAN even though it is written in its feature description. Here is the IOS: c2950-i6k2l2q4-mz.121-22.EA13.bin.
Here is the output of the show version:
####sh version
IOS (tm) C2950 Software (C2950-I6K2L2Q4-M), Version 12.1(22)EA13, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 27-Feb-09 22:20 by amvarma
Image text-base: 0x80010000, data-base: 0x80680000
ROM: Bootstrap program is C2950 boot loader
sw uptime is 34 minutes
System restarted at 08:10:11 GMT Wed Oct 20 2010
System image file is "flash:c2950-i6k2l2q4-mz.121-22.EA13.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2950-24 (RC32300) processor (revision B0) with 19912K bytes of memory.
Processor board ID FOC0543Y03W
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:07:EB:1F:39:40
Motherboard assembly number: 73-5781-08
Power supply part number: NONE
Motherboard serial number: FOC0542041V
Power supply serial number: DAB05411TWP
Model revision number: B0
Model number: WS-C2950-24
System serial number: FOC0543Y03W
Configuration register is 0xF
When I enter into the interface configuration mode, there is no "port monitor" command. Here is the output:
fsw(config)#interface FastEthernet0/2
fsw(config-if)#por
fsw(config-if)#por?
% Unrecognized command
Please could someone tell me what is the problem with this.
Thank you.
Solved! Go to Solution.
10-20-2010 02:00 AM
You need to use the global commands
monitor session x source interface
montior session x destination interface
where x is the span session number and the applicable interfaces follow, you can also specify direction after the interface number
10-20-2010 02:00 AM
10-20-2010 02:10 AM
Thanks, that really helped .
