10-20-2009 12:56 PM
LMS3.2 on Solaris 10
I'm unable to manage in RME the Cisco CGESM switches for HpBlade Enclosure
I'm running cgesm-lanbasek9-mz.122-40.SE.bin image and RME 4.3 device
table says that is is support. Config archive works fine but inventory fails with the following error:
RICS0001:Internal Error,unable to process the collected data from the device
I ran snmpwalk and compared the results with the Cisco 3020 switch and noticed that cgesm switches are missing bunch of mibs including interface mibs. I also tried to add it in the Solarwind and it returned with the error that interface mibs are missing. Please advise.
10-20-2009 02:31 PM
How is this switch configured? Post the IC_Server.log.
10-21-2009 06:56 AM
10-21-2009 09:32 AM
Where is the running config from this switch?
10-22-2009 04:52 AM
10-22-2009 07:38 AM
You are seeing CSCso45451. If you upgrade to 12.2(44)SE2 all these problems with LMS and Solar Winds should go away.
10-22-2009 07:47 AM
Thank you for your help.
10-22-2009 08:26 AM
I have one last quick question, since inventory is not collected for these switches, I will not be able to upgrade the code via CiscoWorks, correct?
10-22-2009 08:32 AM
Correct. You must first do the upgrade manually to get around the bug, then you can use LMS to manage the switch moving forward.
