Cisco configuration management
Anybody know of a Cisco product that works like rancid. I'm trying to avoid using SNMP.
Re: Cisco configuration management
Resource Manager Essentials in CiscoWorks LAN Management Solution can fetch configurations using telnet, SSH, SCP, or RCP. However, LMS requires at least SNMP read-only capability to be able to manage the device.
Kiwi CATTools http://www.kiwisyslog.com/kiwi-cattools-overview/
Solarwinds Cirrus http://www.solarwinds.com/products/cirrus/
I have not used Kiwi in a while, but I use Cirrus all the time. It uses SSH to grab configs.
Hope that helps.
306
