10-14-2005 05:12 AM
This tool is very good, i used it to prepare some 3845 routers and every think is good. The problem is, when i want to order for example Cisco Cat 2950G- 24 ports EI, i want to paste 2 GBICs with it, i can't not like the routers why? The same case for Cat3560G-24TS-S i want to add SFPs with part number is GLC-SX-MM= and without "=", i got this message "Cisco Configuration Tool
Product Not Found
The item GLC-SX-MM= you have entered is not a valid option for this model. Please check your entry and try again.
". I need to make sure for the GBICs and SFPs for the both switches before i place an order. Thank you in advance
10-20-2005 06:23 AM
I think the modules that you have mentioned do not come by default on the models that you want to order. Thats the reason you are getting an error message. You may have to order these modules separately.
10-24-2005 01:44 PM
Yes, i need to order them separately.
Thank you
