09-15-2014 03:18 AM
I am not sure if any one can help with this.
I am trying to get IPSLA monitor working with a Cisco 2911 and to view it through manage engine netflow anaylzer.
does any one know if I need a specific Cisco license to get this feature working
I have ip sla responder as a config option and the instructions, state this is all that is required?
Solved! Go to Solution.
09-15-2014 04:36 AM
Previously no additional license's were required to enable features.
But with the new 15.x versions and later, you need to have your devices license for higher than ipbase.
Any feature set greater than "ipbase" will enable IP SLA. You can check the license details under show version. Example (snippet)
Technology Package License Information for Module:'c2900' ----------------------------------------------------------------- Technology Technology-package Technology-package Current Type Next reboot ------------------------------------------------------------------ ipbase ipbasek9 Permanent ipbasek9 security None None None uc None None None data None None None
Apart from this, you need to enable the datak9 feature.
The 15.x code has licensing features not seen in 12.4, and the "datak9" package has to be accepted.
To check, run a "show license" command, and I see the following:
Index 4 Feature: datak9 Period left: Not Activated Period Used: 0 minute 0 second License Type: EvalRightToUse License State: Not in Use, EULA not accepted License Count: Non-Counted License Priority: None
To activate it, please try the following command:
device(config)#license accept end user agreement accepted the EULA and then: device#license boot module c2900 technology-package datak9
After this please save the config and reboot the device and see you can configure the IP
SLA commands. For more details on how to configure device for IP SLA on 15M IOS, as it has
IP SLA Engine III as compared to IP SLA Engine II on older 12.x series, check the
following details :
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipsla/configuration/15-mt/sla-15-mt-book.html
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
09-15-2014 04:36 AM
following details :
-Thanks
Vinod
09-15-2014 05:52 AM
Vinod
Thank you very much for your prompt response. I am running ipbase, exactly as in your screenshot
I have a 3850 running ipservices, which I have configured for netflow
Am I correct to assume that this should work?
09-15-2014 07:38 AM
I guess 3850 would be running an IOS-XE which should be a little different compared to IOS, due to which I am a little unsure.
Secondly, NetFlow and IP SLA are two separate features. Please confirm which feature do you mean?
Also share specific version details of the platform.
-Thanks
Vinod
09-15-2014 08:43 AM
Sorry that wasn't clear
I am interested in the IP SLA feature and I am running
Switch Ports Model SW Version SW Image Mode
* 1 32 WS-C3850-24T 03.03.03SE cat3k_caa-universalk9 INSTALL
09-15-2014 08:58 AM
Starting with Cisco IOS Release 15.1(1)SG and Cisco IOS XE Release 3.3.0SG, support for all IP SLAs and NSF features have been extended from Enterprise Services to IP Base feature set.
So as far as you have anything higher to ipbase, IP SLA should work on 8850 as well.
For more details, you can check the Configuration Guide for 3850 for IOS-XE 3.3.03SE IP SLA Feature
-Thanks
Vinod
