Cisco LMS 3.2.1 Causing Switch CPU Spike
We have LMS 3.2.1 cauing CPU Spike on all the LAN switches. I treid to apply the commands as per the below URL but still the issue is same.
I had attached Show version, Show stacks and Show process cpu sorted output.
sh version
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01080000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
ATCBmer-OPERas08 uptime is 30 weeks, 1 day, 3 hours, 20 minutes
System restarted at 08:19:08 UTC Tue Jul 2 2013
System image file is "flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE5.bin"
cisco WS-C3750-48TS (PowerPC405) processor (revision Q0) with 118784K/12280K bytes of memory.
Processor board ID FDO1339Y2FC
Last reset from power-on
2 Virtual Ethernet interfaces
96 FastEthernet interfaces
8 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : EC:30:91:4A:CF:80
Motherboard assembly number     : 73-9680-12
Power supply part number        : 341-0028-02
Motherboard serial number       : FDO133916XY
Power supply serial number      : DTN133510WF
Model revision number           : Q0
Motherboard revision number     : A0
Model number                    : WS-C3750-48TS-S
System serial number            : FDO1339Y2FC
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : FDO13390UPX
Top Assembly Part Number        : 800-25854-04
Top Assembly Revision Number    : A0
Version ID                      : V07
CLEI Code Number                : COMD200BRA
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
     1   52     WS-C3750-48TS      12.2(35)SE5             C3750-IPBASE-M
*    2   52     WS-C3750-48TS      12.2(35)SE5             C3750-IPBASE-M
Switch 01
Switch Uptime                   : 30 weeks, 1 day, 15 minutes
Base ethernet MAC Address       : EC:30:91:4A:D0:80
Motherboard serial number       : FDO133916ZJ
Power supply serial number      : DTN133510WC
System serial number            : FDO1339Y2FB
SFP Module revision number      : A0
SFP Module serial number        : FDO13390UPS
Top assembly part number        : 800-25854-04
Top assembly revision number    : A0
Version ID                      : V07
Configuration register is 0xF
#sh processes cpu sorted
CPU utilization for five seconds: 7%/1%; one minute: 7%; five minutes: 7%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
251        2051       209       9813  0.79%  0.32%  0.36%   6 Virtual Exec
131    61393351 248916997        246  0.63%  0.71%  0.60%   0 HL2MCM
123     6997778   3642657       1921  0.15%  0.03%  0.00%   0 HQM Stack Proces
191   105112370 573529786        183  0.15%  0.29%  0.30%   0 IGMPSN
124    29851586  14567458       2049  0.15%  0.17%  0.15%   0 HRPC qos request
115     4380679 434564249         10  0.15%  0.03%  0.00%   0 Hulc LED Process
   7           0         1          0  0.00%  0.00%  0.00%   0 HRPC asic-stats
   8           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
   9       23632    348343         67  0.00%  0.00%  0.00%   0 ARP Input
  10           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  11           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  12           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  13          42        11       3818  0.00%  0.00%  0.00%   0 Entity MIB API
  14           0         1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  15         242    304021          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  16           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  17        5029  18121023          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  18           0       156          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  19        5258  18121026          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  20           9       157         57  0.00%  0.00%  0.00%   0 IPC Seat Manager
  21           0         1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  22      194590   5460341         35  0.00%  0.00%  0.00%   0 HC Counter Timer
  23        6925  18121021          0  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  24           0         1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  25           0         1          0  0.00%  0.00%  0.00%   0 License IPC stat
  26           0         1          0  0.00%  0.00%  0.00%   0 License IPC serv
  27        5093  18120999          0  0.00%  0.00%  0.00%   0 GraphIt
  28           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  29           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  30      308341  44341035          6  0.00%  0.00%  0.00%   0 Net Background
  31           0         1          0  0.00%  0.00%  0.00%   0 IDB Work
   3           0        19          0  0.00%  0.00%  0.00%   0 SNMP Timers
   4    18484344   2158292       8564  0.00%  0.10%  0.06%   0 Check heaps
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
  35     4296336    307754      13960  0.00%  0.01%  0.00%   0 Per-minute Jobs
  36           0        33          0  0.00%  0.00%  0.00%   0 AggMgr Process
  37           8        26        307  0.00%  0.00%  0.00%   0 Net Input
  38     5416553   3642636       1486  0.00%  0.00%  0.00%   0 Compute load avg
  39          25        10       2500  0.00%  0.00%  0.00%   0 Collection proce
  40       20231 362215119          0  0.00%  0.00%  0.00%   0 DownWhenLooped
  41           0         1          0  0.00%  0.00%  0.00%   0 HRPC hdwl reques
  42           0         1          0  0.00%  0.00%  0.00%   0 HRPC emac reques
  43           0         3          0  0.00%  0.00%  0.00%   0 HRPC lpip reques
  44           0         4          0  0.00%  0.00%  0.00%   0 HLPIP Sync Proce
  45           0         3          0  0.00%  0.00%  0.00%   0 HRPC Multi-FS Sy
  46           0        15          0  0.00%  0.00%  0.00%   0 HULC multifs pro
  47           0         2          0  0.00%  0.00%  0.00%   0 MIRAGE RBCP Moni
   2        1468   3642677          0  0.00%  0.00%  0.00%   0 Load Meter
  49           0        16          0  0.00%  0.00%  0.00%   0 Stack Mgr
  50         678        42      16142  0.00%  0.00%  0.00%   0 Stack Mgr Notifi
  51     3155448 977563359          3  0.00%  0.01%  0.00%   0 Fifo Error Detec
  52          16        11       1454  0.00%  0.00%  0.00%   0 Adjust Regions
  53       44680  18121002          2  0.00%  0.00%  0.00%   0 hrpc -> response
  54      443728  28994073         15  0.00%  0.00%  0.00%   0 hrpc -> request
  55     6463350  36914367        175  0.00%  0.00%  0.00%   0 hrpc <- response
  56           0         3          0  0.00%  0.00%  0.00%   0 HRPC hcomp reque
  57           0        22          0  0.00%  0.00%  0.00%   0 HULC Device Mana
  32          48      8960          5  0.00%  0.00%  0.00%   0 Logger
  59           0         7          0  0.00%  0.00%  0.00%   0 HRPC hdm blockin
  60          25         4       6250  0.00%  0.00%  0.00%   0 HRPC cfg_backup
  61       90371   3642630         24  0.00%  0.00%  0.00%   0 HIPC bkgrd proce
   5        8473      3810       2223  0.00%  0.00%  0.00%   0 Pool Manager
  34       52605  18121026          2  0.00%  0.00%  0.00%   0 Per-Second Jobs
  33        6963  18120995          0  0.00%  0.00%  0.00%   0 TTY Background
  65        1281      7231        177  0.00%  0.00%  0.00%   0 HRPC hpsecure re
  48           0         1          0  0.00%  0.00%  0.00%   0 HRPC hsm request
  67      238024 542998290          0  0.00%  0.00%  0.00%   0 HLFM address lea
  68        6856  18120996          0  0.00%  0.00%  0.00%   0 HLFM aging proce
  69      139202 543008514          0  0.00%  0.00%  0.00%   0 HLFM address ret
  70           0         1          0  0.00%  0.00%  0.00%   0 HRPC hrcmd reque
  71       94414    693286        136  0.00%  0.00%  0.00%   0 HRPC hulc misc r
  72           0         3          0  0.00%  0.00%  0.00%   0 HRPC system mtu
  73        3828   6074329          0  0.00%  0.00%  0.00%   0 HVLAN main bkgrd
  74     1477074   5127744        288  0.00%  0.00%  0.00%   0 IP SNMP
  75           0         2          0  0.00%  0.00%  0.00%   0 Vlan shutdown Pr
  76       27087    170972        158  0.00%  0.00%  0.00%   0 HRPC vlan reques
  77           0         2          0  0.00%  0.00%  0.00%   0 HULC VLAN REF Ba
  78           0         5          0  0.00%  0.00%  0.00%   0 HRPC hfbm reques
  79        4132  18120976          0  0.00%  0.00%  0.00%   0 MDFS LC Download
  80           0         5          0  0.00%  0.00%  0.00%   0 HRPC ilp request
  81           0         1          0  0.00%  0.00%  0.00%   0 HPM Msg Retry Pr
  82         470     74807          6  0.00%  0.00%  0.00%   0 TACACS+
  83      816214 201441346          4  0.00%  0.00%  0.00%   0 hpm main process
  84         313      7676         40  0.00%  0.00%  0.00%   0 HPM Stack Sync P
  85        6174     28492        216  0.00%  0.00%  0.00%   0 HRPC pm request
  86           0         3          0  0.00%  0.00%  0.00%   0 HPM if_num mappi
  87    11970484  37978485        315  0.00%  0.07%  0.05%   0 hpm counter proc
  88     8254076  39504043        208  0.00%  0.01%  0.02%   0 HRPC pm-counters
  89           0         1          0  0.00%  0.00%  0.00%   0 hpm vp events ca
  90           0       235          0  0.00%  0.00%  0.00%   0 HRPC hcmp reques
  91           8      8695          0  0.00%  0.00%  0.00%   0 HCEF ADJ Refresh
  92           0         1          0  0.00%  0.00%  0.00%   0 HRPC hl3mm reque
  93           0         1          0  0.00%  0.00%  0.00%   0 hl3md_rpfq_thrl_
  94       78051  12727882          6  0.00%  0.00%  0.00%   0 hl3mm
  58           0        17          0  0.00%  0.00%  0.00%   0 HRPC hdm non blo
  96           0         4          0  0.00%  0.00%  0.00%   0 HRPC acl request
  97           8        55        145  0.00%  0.00%  0.00%   0 HACL Acl Manager
  98           0         1          0  0.00%  0.00%  0.00%   0 HRPC backup inte
  99           0         1          0  0.00%  0.00%  0.00%   0 HRPC cdp request
100        1622     13860        117  0.00%  0.00%  0.00%   0 HRPC dot1x reque
101        3284     12837        255  0.00%  0.00%  0.00%   0 HULC DOT1X Proce
102           0         1          0  0.00%  0.00%  0.00%   0 HRPC foxhound re
103           0         2          0  0.00%  0.00%  0.00%   0 Hulc Foxhound Pr
104           0         1          0  0.00%  0.00%  0.00%   0 HRPC sdm request
105      180683  90585811          1  0.00%  0.00%  0.00%   0 Hulc Storm Contr
106           0         2          0  0.00%  0.00%  0.00%   0 HSTP Sync Proces
107         285     10024         28  0.00%  0.00%  0.00%   0 HRPC stp_cli req
108          17       100        170  0.00%  0.00%  0.00%   0 HRPC stp_state_s
109           0         2          0  0.00%  0.00%  0.00%   0 S/W Bridge Proce
110           0        22          0  0.00%  0.00%  0.00%   0 HRPC hudld reque
111           0         1          0  0.00%  0.00%  0.00%   0 HRPC vqpc reques
112           0         1          0  0.00%  0.00%  0.00%   0 HRPC iec_load_ba
113           0        14          0  0.00%  0.00%  0.00%   0 HRPC l2pt qnq rp
114           0         3          0  0.00%  0.00%  0.00%   0 HRPC hled reques
   1         795     10877         73  0.00%  0.00%  0.00%   0 Chunk Manager
116       61910  13347463          4  0.00%  0.00%  0.00%   0 HL3U bkgrd proce
117      572759   7248461         79  0.00%  0.00%  0.00%   0 HRPC hl3u reques
118        1586   4165623          0  0.00%  0.00%  0.00%   0 HL3U PBR bkgrd p
119         186    152011          1  0.00%  0.00%  0.00%   0 HL3U PBR n-h res
120           0         1          0  0.00%  0.00%  0.00%   0 HRPC dtp request
121           0         1          0  0.00%  0.00%  0.00%   0 HRPC show_forwar
122         175        60       2916  0.00%  0.00%  0.00%   0 HRPC snmp reques
  62           0         1          0  0.00%  0.00%  0.00%   0 IPC RTTYC Messag
  63           0         1          0  0.00%  0.00%  0.00%   0 RTTYC Flush
  64        1050      6840        153  0.00%  0.00%  0.00%   0 Hulc Port-Securi
126           0         1          0  0.00%  0.00%  0.00%   0 HRPC obfl reques
  66       22215    141914        156  0.00%  0.00%  0.00%   0 HRPC hlfm reques
128           0         9          0  0.00%  0.00%  0.00%   0 Hulc Reload Mana
129           8        19        421  0.00%  0.00%  0.00%   0 HRPC hrcli-event
130       50722     21263       2385  0.00%  0.00%  0.00%   0 HRPC rfs request
  95           0         1          0  0.00%  0.00%  0.00%   0 HACL Queue Proce
132           8         8       1000  0.00%  0.00%  0.00%   0 HL2MCM
133           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
134           0         3          0  0.00%  0.00%  0.00%   0 CEF switching ba
135       53206  18120990          2  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
136         154      7422         20  0.00%  0.00%  0.00%   0 Switch Backup In
137         313    304021          1  0.00%  0.00%  0.00%   0 MMN bkgrd proces
138           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
139           0         1          0  0.00%  0.00%  0.00%   0 MAB Framework
140         567      3467        163  0.00%  0.00%  0.00%   0 802.1x switch
141           0         1          0  0.00%  0.00%  0.00%   0 802.1x Webauth F
142           0         1          0  0.00%  0.00%  0.00%   0 802.1x Critical
143       81511   1214105         67  0.00%  0.00%  0.00%   0 DTP Protocol
144           0         1          0  0.00%  0.00%  0.00%   0 EAP Framework
145           0         1          0  0.00%  0.00%  0.00%   0 HRPC dai request
146           0         1          0  0.00%  0.00%  0.00%   0 HULC DAI Process
147           0         5          0  0.00%  0.00%  0.00%   0 HRPC dhcp snoopi
148           0         5          0  0.00%  0.00%  0.00%   0 HULC DHCP Snoopi
149           0         1          0  0.00%  0.00%  0.00%   0 HRPC ip source g
150           0         1          0  0.00%  0.00%  0.00%   0 HULC IP Source g
151        7033  18242384          0  0.00%  0.00%  0.00%   0 UDLD
152         125    608080          0  0.00%  0.00%  0.00%   0 Port-Security
153           0         3          0  0.00%  0.00%  0.00%   0 OBFL Cfg Dispatc
154           0         2          0  0.00%  0.00%  0.00%   0 Switch IP Host T
155           0         1          0  0.00%  0.00%  0.00%   0 Link State Group
156         367   1823271          0  0.00%  0.00%  0.00%   0 Ethchnl
157         303      2174        139  0.00%  0.00%  0.00%   0 VMATM Callback
158       23146 181145818          0  0.00%  0.00%  0.00%   0 MDFS MFIB Proces
159           0         1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Redistr
160           9         2       4500  0.00%  0.00%  0.00%   0 AAA Server
161           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
162           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
163     8780828  15301673        573  0.00%  0.01%  0.00%   0 CDP Protocol
164       13401      6681       2005  0.00%  0.00%  0.00%   0 SNMP Traps
165           0         1          0  0.00%  0.00%  0.00%   0 image mgr
166           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
167         139    152026          0  0.00%  0.00%  0.00%   0 DHCP Snooping
168     4637569  47657943         97  0.00%  0.07%  0.04%   0 IP Input
169           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
170    10066119  69946340        143  0.00%  0.04%  0.05%   0 Spanning Tree
171          24    304027          0  0.00%  0.00%  0.00%   0 Spanning Tree St
172       53121    364742        145  0.00%  0.00%  0.00%   0 CEF background p
173           0         1          0  0.00%  0.00%  0.00%   0 IP IRDP
174          16         2       8000  0.00%  0.00%  0.00%   0 CEF RF HULC Conv
175         162      3972         40  0.00%  0.00%  0.00%   0 XDR mcast
176       21665     37317        580  0.00%  0.00%  0.00%   0 AAA Accounting
178           0         4          0  0.00%  0.00%  0.00%   0 MDFS LC Process
179          41    228026          0  0.00%  0.00%  0.00%   0 Cluster L2
180         487   1823270          0  0.00%  0.00%  0.00%   0 Cluster RARP
181        1274   2279503          0  0.00%  0.00%  0.00%   0 Cluster Base
182        4979    582218          8  0.00%  0.00%  0.00%   0 TCP Timer
183        2534      4377        578  0.00%  0.00%  0.00%   0 TCP Protocols
184           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
185         370     61248          6  0.00%  0.00%  0.00%   0 HTTP CORE
186           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
187         191       357        535  0.00%  0.00%  0.00%   1 Virtual Exec
188         312       796        391  0.00%  0.00%  0.00%   2 Virtual Exec
189        5986      3688       1623  0.00%  0.00%  0.00%   0 IGMPSN L2MCM
190     1988996  22053535         90  0.00%  0.02%  0.00%   0 IGMPSN MRD
125           0         1          0  0.00%  0.00%  0.00%   0 HRPC span reques
192           0         1          0  0.00%  0.00%  0.00%   0 IGMPQR
193           0         1          0  0.00%  0.00%  0.00%   0 CEF MQC IPC Back
194           0         2          0  0.00%  0.00%  0.00%   0 L2TRACE SERVER
195        2867      3686        777  0.00%  0.00%  0.00%   0 MLDSN L2MCM
196           0         1          0  0.00%  0.00%  0.00%   0 MRD
197           0         1          0  0.00%  0.00%  0.00%   0 MLD_SNOOP
198      149666  28335503          5  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
199        2752    303845          9  0.00%  0.00%  0.00%   0 IP RIB Update
200           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
201           9     60808          0  0.00%  0.00%  0.00%   0 IP Admin SM Proc
202      189407    791688        239  0.00%  0.00%  0.00%   0 DHCPD Receive
203          25    152012          0  0.00%  0.00%  0.00%   0 DHCPD Timer
204           0         2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
205           0         2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
206           9         2       4500  0.00%  0.00%  0.00%   0 TPLUS
207           0         1          0  0.00%  0.00%  0.00%   0 HRPC x_setup req
208           9        39        230  0.00%  0.00%  0.00%   0 VTP Trap Process
209           0         2          0  0.00%  0.00%  0.00%   0 VTPMIB EDIT BUFF
210           0         2          0  0.00%  0.00%  0.00%   0 DHCP Security He
211           0         1          0  0.00%  0.00%  0.00%   0 HCD Process
212           0         1          0  0.00%  0.00%  0.00%   0 HRPC cable diagn
213           0         2          0  0.00%  0.00%  0.00%   0 DiagCard2/-1
214      134713 218636042          0  0.00%  0.00%  0.00%   0 PM Callback
215           0        20          0  0.00%  0.00%  0.00%   0 VLAN Manager
216       97175   5167135         18  0.00%  0.00%  0.00%   0 DHCPD Database
217         133   1458592          0  0.00%  0.00%  0.00%   0 dhcp snooping sw
218           0         1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
219           0         3          0  0.00%  0.00%  0.00%   0 RADIUS TEST CMD
220           0         2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
221        9523      2686       3545  0.00%  0.00%  0.00%   0 Syslog Traps
222           0         1          0  0.00%  0.00%  0.00%   0 SAA MPLSLM Proce
223          93      2217         41  0.00%  0.00%  0.00%   0 ADJ background
224           0         2          0  0.00%  0.00%  0.00%   0 STP FAST TRANSIT
225           9       135         66  0.00%  0.00%  0.00%   0 CSRT RAPID TRANS
226       20638    168875        122  0.00%  0.00%  0.00%   0 HRPC hl2mcm igmp
227           0        38          0  0.00%  0.00%  0.00%   0 HRPC hl2mcm mlds
228         446       765        583  0.00%  0.00%  0.00%   3 Virtual Exec
229        6840      1901       3598  0.00%  0.00%  0.00%   0 SpanTree Helper
230           0         1          0  0.00%  0.00%  0.00%   0 DiagCard1/-1
231           0         1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
232          94       420        223  0.00%  0.00%  0.00%   0 SpanTree Flush
233       22092    540058         40  0.00%  0.00%  0.00%   0 IP Background
234      833188   2574651        323  0.00%  0.00%  0.00%   0 PDU DISPATCHER
235    22681449   5799556       3910  0.00%  0.00%  0.00%   0 SNMP ENGINE
236           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
237       16028  18381176          0  0.00%  0.00%  0.00%   0 NTP
238          33       139        237  0.00%  0.00%  0.00%   0 hulc cfg mgr mas
239       98617       500     197234  0.00%  0.00%  0.00%   0 hulc running con
240           0         1          0  0.00%  0.00%  0.00%   0 RTTYS Process
241         335    303847          1  0.00%  0.00%  0.00%   0 802.1x MDA Aging
242         346       513        674  0.00%  0.00%  0.00%   4 Virtual Exec
243         628       999        628  0.00%  0.00%  0.00%   5 Virtual Exec
244         321    101289          3  0.00%  0.00%  0.00%   0 HCMP sync proces
245           0         2          0  0.00%  0.00%  0.00%   0 hulc_tb_process
246     1629625  18112558         89  0.00%  0.00%  0.00%   0 IPC LC Message H
247           0         2          0  0.00%  0.00%  0.00%   0 XDR RP Ping Back
248         181    151926          1  0.00%  0.00%  0.00%   0 XDR RP backgroun
249           0         1          0  0.00%  0.00%  0.00%   0 XDR RP Test Back
250           9         5       1800  0.00%  0.00%  0.00%   0 CEF RP IPC Backg
127           0        14          0  0.00%  0.00%  0.00%   0 HRPC system post
252         441       613        719  0.00%  0.00%  0.00%   7 Virtual Exec
254         626      1254        499  0.00%  0.00%  0.00%   9 Virtual Exec
sh stacks
Minimum process stacks:
Free/Size   Name
5112/6000   hulc_flash init
5740/6000   CDP BLOB
8572/9000   IP Background
5664/6000   vqpc_shim_create_addr_tbl
5648/6000   SPAN Subsystem
5396/6000   LICENSE AGENT DEFAULT
5684/6000   stp_change_tree_type
8732/9000   cdp init process
8576/12000  Init
5644/6000   IPC Zone Manager
5720/6000   RTTY Slave Registration Process
4792/6000   IPC Split Init
5244/6000   HUDLD fiber table process
5496/6000   bulk config process
5496/6000   RADIUS INITCONFIG
2600/3000   Rom Random Update Process
5228/6000   MDFS LC IPC Init Process
5420/6000   HVLAN Mapped Vlan Id Update Process
8284/12000  cfg mgr new master process
4908/6000   hpm bulk_vlan_state process
5676/6000   HDF Stack-Mac
5724/6000   HCMP redirect process
5648/6000   HCMP new mac process
5352/6000   XDR LC PRIO Background
9652/12000  XDR LC Background
5388/6000   CEF LC Stats
5396/6000   CEF LC IPC Background
5368/6000   HL3U ARP Refresh Proc
5128/6000   RTTY Client Registration
5152/6000   IPC LC Port Opener
35132/36000  TCP Command
7644/12000  Virtual Exec
19784/24000  hulc_techsupport_process
Interrupt level stacks:
Level    Called Unused/Size  Name
  4  1981299888   7808/9000  NETWORK INTERFACE CHIP
  5           0   9000/9000  SUPERVISOR EXCEPTIONS
  6        6937   8932/9000  NS16550 VECTOR
Please help me in solving the issue.
Nibin Rodrigues
Re: Cisco LMS 3.2.1 Causing Switch CPU Spike
Outputs are not helpful. As the CPU seems to have dropped to 7% when you collected the output.
You need to share the output when the CPU spikes, else necessary info will be lost.
You can configure your one of the device with issue with an EEM script to have this collected when the CPU spikes more than 80%.
Please check this script and share the output:
event manager applet cpu_stats
event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op gt entry-val 80 exit-op lt exit-val 70 poll-interval 5
action 1.1 syslog msg "------HIGH CPU DETECTED----, CPU: $_snmp_oid_val %"
action 1.2 cli command "enable"
action 1.3 cli command "show clock | append disk0:cpu_stats"
action 1.4 cli command "show stack 235 | append disk0:cpu_stats"
action 1.5 cli command "show proc cpu sort | append disk0:cpu_stats"
If the device is configured for AAA, config it for privileges to be able to collect ouput with:
event manager session cli username
** Please edit disk0: as per the file system on your device, like flash: etc.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hi, Finally I got output from
Finally I got output from EEM. Still facing issue with CPU spike (reaching above 90% every 3 hours)  Kindly let me know which process/poll from LMS causing spike.
more cpu_stats
08:34:50.900 UTC Sun Jul 13 2014
Process 235:  IP ACL XDR LC Background
  Stack segment 0x5A69684 - 0x5A6ADF4
  FP: 0x5A6ADC0, RA: 0x294A248
  FP: 0x5A6ADE0, RA: 0x1013B38
  FP: 0x5A6ADE8, RA: 0x1BCF948
  FP: 0x0, RA: 0x1BC63C0
CPU utilization for five seconds: 99%/1%; one minute: 32%; five minutes: 18%
 234       19360    235134         82 85.62%  8.55%  2.94%   1 Virtual Exec
  71   1093114471690141903         64  2.39%  0.74%  0.46%   0 Fifo Error Detec
 110   291896714  66860698       4365  1.27%  0.87%  0.85%   0 hpm counter proc
 333         144       134       1074  0.95%  0.07%  0.01%   2 Virtual Exec
  93   209133659   3226190      64823  0.47%  0.56%  0.58%   0 HULC Tcam Memory
 158   124730186   6452441      19330  0.47%  0.37%  0.35%   0 HQM Stack Proces
 315          26        24       1083  0.31%  0.02%  0.00%   0 EEM Callback Thr
 149    70316360 921938032         76  0.31%  0.17%  0.16%   0 Hulc LED Process
   3     1984170  49712892         39  0.15%  0.03%  0.00%   0 CEF: IPv4 proces
  75    30660149 133990691        228  0.15%  0.08%  0.06%   0 hrpc <- response
 168    81754951 291989576        279  0.15%  0.16%  0.19%   0 HL2MCM
 159   106398380  51587099       2062  0.15%  0.38%  0.36%   0 HRPC qos request
 135     3265881 160225069         20  0.15%  0.01%  0.00%   0 Hulc Storm Contr
 170     2324295  32252873         72  0.15%  0.03%  0.00%   0 PI MATM Aging Pr
 106    13216454 370564211         35  0.15%  0.04%  0.01%   0 hpm main process
  31    21256458   3937866       5397  0.15%  0.07%  0.05%   0 Net Background
 224    42191188 212546120        198  0.15%  0.09%  0.09%   0 Spanning Tree
  87    12713230 948699751         13  0.15%  0.04%  0.01%   0 HLFM address lea
  35     3270263  32320941        101  0.15%  0.01%  0.00%   0 Per-Second Jobs
  19           0        40          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  18      110764  32253004          3  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  17           0        21          0  0.00%  0.00%  0.00%   0 ADJ background
  16       16573    541197         30  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  20       91946  32253007          2  0.00%  0.00%  0.00%   0 IPC Deferred Por
  21      476008   8653999         55  0.00%  0.00%  0.00%   0 IPC Seat Manager
  26           0         1          0  0.00%  0.00%  0.00%   0 License IPC stat
  15           0         1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  28       91032  32252876          2  0.00%  0.00%  0.00%   0 GraphIt
  22           0         1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  23          75         4      18750  0.00%  0.00%  0.00%   0 PrstVbl
  14          93        30       3100  0.00%  0.00%  0.00%   0 Entity MIB API
  32           0         1          0  0.00%  0.00%  0.00%   0 IDB Work
  33        3419     19354        176  0.00%  0.00%  0.00%   0 Logger
  24      117864  32253002          3  0.00%  0.01%  0.00%   0 Dynamic ARP Insp
  25           0         1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  36    14375584    553673      25964  0.00%  0.04%  0.00%   0 Per-minute Jobs
  27           0         1          0  0.00%  0.00%  0.00%   0 License IPC serv
  38         239     10986         21  0.00%  0.00%  0.00%   0 IF-MGR event pro
  39           0         5          0  0.00%  0.00%  0.00%   0 IP Admission HA
  40    25033048   6677903       3748  0.00%  0.08%  0.08%   0 Compute load avg
  41           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  29           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  43     2892158   6958636        415  0.00%  0.00%  0.00%   0 HC Counter Timer
  44           0         1          0  0.00%  0.00%  0.00%   0 SFF8472
  13           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  46           0         1          0  0.00%  0.00%  0.00%   0 HULC PBR Tcam Me
  12           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  30           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  34      103029  32252868          3  0.00%  0.00%  0.00%   0 TTY Background
  50           0         1          0  0.00%  0.00%  0.00%   0 HRPC actual powe
  51           0         3          0  0.00%  0.00%  0.00%   0 HRPC lpip reques
  52           0         2          0  0.00%  0.00%  0.00%   0 HLPIP Sync Proce
  53           0         3          0  0.00%  0.00%  0.00%   0 HRPC Multi-FS Sy
  54           8        18        444  0.00%  0.00%  0.00%   0 HULC multifs pro
  55           0         1          0  0.00%  0.00%  0.00%   0 HRPC hnetwpol re
  56           0         1          0  0.00%  0.00%  0.00%   0 Hulc Warm Upgrad
  57           0         1          0  0.00%  0.00%  0.00%   0 HRPC ipadm reque
  37          33        12       2750  0.00%  0.00%  0.00%   0 IF-MGR control p
  59           0         1          0  0.00%  0.00%  0.00%   0 HULC QM Tcam Mem
  60      190380   1224938        155  0.00%  0.00%  0.00%   0 EEM ED ND
  61           0       123          0  0.00%  0.00%  0.00%   0 EEM ED Identity
  62           0       245          0  0.00%  0.00%  0.00%   0 EEM ED MAT
  63      111903   6452385         17  0.00%  0.00%  0.00%   0 Hulc LED Alchemy
  42          35      5315          6  0.00%  0.00%  0.00%   0 Transport Port A
  65    52048843 720046943         72  0.00%  0.16%  0.16%   0 RedEarth Tx Mana
  66     53937781261032382          4  0.00%  0.01%  0.00%   0 RedEarth Rx Mana
  67        2311    216575         10  0.00%  0.00%  0.00%   0 HULC Thermal Pro
  68           0         1          0  0.00%  0.00%  0.00%   0 HRPC hsm request
  69           0        56          0  0.00%  0.00%  0.00%   0 Stack Mgr
  70        2510       248      10120  0.00%  0.00%  0.00%   0 Stack Mgr Notifi
  10           0         1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  72           0         3          0  0.00%  0.00%  0.00%   0 Adjust Regions
  45      694015 640293487          1  0.00%  0.00%  0.00%   0 DownWhenLooped
  74     1646076  69449052         23  0.00%  0.00%  0.00%   0 hrpc -> request
   9       67025    599011        111  0.00%  0.00%  0.00%   0 ARP Input
  76           0         7          0  0.00%  0.00%  0.00%   0 HRPC hcomp reque
  77           0        54          0  0.00%  0.00%  0.00%   0 HULC Device Mana
  78       10438     30037        347  0.00%  0.00%  0.00%   0 HRPC hdm non blo
  47           0         1          0  0.00%  0.00%  0.00%   0 HULC ACL Tcam Me
  81      124554   6452387         19  0.00%  0.00%  0.00%   0 HIPC bkgrd proce
  82           0         1          0  0.00%  0.00%  0.00%   0 IPC RTTYC Messag
  11           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  48           0         1          0  0.00%  0.00%  0.00%   0 HRPC hdwl reques
  49           0         1          0  0.00%  0.00%  0.00%   0 HRPC EnergyWise
  58           0         2          0  0.00%  0.00%  0.00%   0 SM RBCP Monitor
  88      133387  32252876          4  0.00%  0.00%  0.00%   0 HLFM aging proce
  89     3109394 948830216          3  0.00%  0.00%  0.00%   0 HLFM address ret
  90           0         1          0  0.00%  0.00%  0.00%   0 HRPC hrcmd reque
  91           0         1          0  0.00%  0.00%  0.00%   0 HRPC emac reques
  92      267066    852731        313  0.00%  0.00%  0.00%   0 HRPC hulc misc r
   5       29303    892572         32  0.00%  0.00%  0.00%   0 Pool Manager
  94       71237  10798283          6  0.00%  0.00%  0.00%   0 HVLAN main bkgrd
  95      249139    557119        447  0.00%  0.00%  0.00%   0 IP Background
  96           0         2          0  0.00%  0.00%  0.00%   0 Vlan shutdown Pr
  97       34932    206235        169  0.00%  0.00%  0.00%   0 HRPC vlan reques
  98           0         1          0  0.00%  0.00%  0.00%   0 HULC VLAN REF Ba
  99       30454    541194         56  0.00%  0.00%  0.00%   0 hulc_xps_process
 100           8         9        888  0.00%  0.00%  0.00%   0 HRPC hfbm reques
 101           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
 102           0        13          0  0.00%  0.00%  0.00%   0 HRPC ilp request
 103           0         1          0  0.00%  0.00%  0.00%   0 HULC PM Vector P
 104           0         1          0  0.00%  0.00%  0.00%   0 HPM Msg Retry Pr
 105          53      1767         29  0.00%  0.00%  0.00%   0 TACACS+
  64           0         1          0  0.00%  0.00%  0.00%   0 HRPC asic-stats
 107         425      3060        138  0.00%  0.00%  0.00%   0 HPM Stack Sync P
 108       20145     75351        267  0.00%  0.00%  0.00%   0 HRPC pm request
 109           0         5          0  0.00%  0.00%  0.00%   0 HPM if_num mappi
   4   313387584  14473401      21652  0.00%  0.53%  0.81%   0 Check heaps
 111    46264013 207669797        222  0.00%  0.10%  0.12%   0 HRPC pm-counters
   2      122556   6486432         18  0.00%  0.00%  0.00%   0 Load Meter
 113           0       237          0  0.00%  0.00%  0.00%   0 HRPC hcmp reques
 114          32     15472          2  0.00%  0.00%  0.00%   0 HCEF ADJ Refresh
 115           0         1          0  0.00%  0.00%  0.00%   0 HRPC hl3mm reque
 116           0         1          0  0.00%  0.00%  0.00%   0 hl3md_rpfq_thrl_
  73     1542060  32252892         47  0.00%  0.01%  0.00%   0 hrpc -> response
 118       63793  16130954          3  0.00%  0.00%  0.00%   0 hl3mm_rp
 119           0         1          0  0.00%  0.00%  0.00%   0 HACL Queue Proce
 120           0         4          0  0.00%  0.00%  0.00%   0 HRPC acl request
 121           0        43          0  0.00%  0.00%  0.00%   0 HACL Acl Manager
 122           0         1          0  0.00%  0.00%  0.00%   0 HRPC backup inte
 123           0         1          0  0.00%  0.00%  0.00%   0 HRPC cdp request
 124           0         3          0  0.00%  0.00%  0.00%   0 HRPC lldp reques
 125           0         5          0  0.00%  0.00%  0.00%   0 HULC CISP Proces
 126        4577     39096        117  0.00%  0.00%  0.00%   0 HRPC dot1x reque
 127           0         1          0  0.00%  0.00%  0.00%   0 Dot1X Msg Retry
 128        3417     22012        155  0.00%  0.00%  0.00%   0 HULC DOT1X Proce
 129           0         1          0  0.00%  0.00%  0.00%   0 HRPC foxhound re
 130           0         2          0  0.00%  0.00%  0.00%   0 Hulc Foxhound Pr
 131           0         7          0  0.00%  0.00%  0.00%   0 HRPC system mtu
 132           0         1          0  0.00%  0.00%  0.00%   0 SMI MSG Retry Pr
 133           0         4          0  0.00%  0.00%  0.00%   0 HRPC Smart Insta
 134           0         1          0  0.00%  0.00%  0.00%   0 HRPC sdm request
   7          27       342         78  0.00%  0.00%  0.00%   0 Net Input
 136           0         2          0  0.00%  0.00%  0.00%   0 HSTP Sync Proces
 137         485      4964         97  0.00%  0.00%  0.00%   0 HRPC stp_cli req
 138         626      4086        153  0.00%  0.00%  0.00%   0 HRPC stp_state_s
 139           0         2          0  0.00%  0.00%  0.00%   0 S/W Bridge Proce
 140           0        95          0  0.00%  0.00%  0.00%   0 HRPC hudld reque
 141           0         1          0  0.00%  0.00%  0.00%   0 HRPC vqpc reques
 142           0         1          0  0.00%  0.00%  0.00%   0 BCM cable diags
 143           0         1          0  0.00%  0.00%  0.00%   0 HRPC iec_load_ba
 144           9        36        250  0.00%  0.00%  0.00%   0 HRPC l2pt qnq rp
 145           0         1          0  0.00%  0.00%  0.00%   0 HRPC aim request
 146           0         2          0  0.00%  0.00%  0.00%   0 MACsec Process
 147           0         1          0  0.00%  0.00%  0.00%   0 HRPC macsec requ
 148           8        11        727  0.00%  0.00%  0.00%   0 HRPC hled reques
   1      101398   1612550         62  0.00%  0.00%  0.00%   0 Chunk Manager
 150      877240  23650115         37  0.00%  0.00%  0.00%   0 HL3U bkgrd proce
 151     3373734  38687769         87  0.00%  0.00%  0.00%   0 HRPC hl3u reques
 152       25962   7416600          3  0.00%  0.00%  0.00%   0 HL3U PBR bkgrd p
 153        1180    270720          4  0.00%  0.00%  0.00%   0 HL3U PBR n-h res
 154           0         1          0  0.00%  0.00%  0.00%   0 HRPC dtp request
 155           0         1          0  0.00%  0.00%  0.00%   0 HRPC show_forwar
 156          34       127        267  0.00%  0.00%  0.00%   0 HRPC snmp reques
  79           0        15          0  0.00%  0.00%  0.00%   0 HRPC hdm blockin
  80          16         6       2666  0.00%  0.00%  0.00%   0 HRPC cfg_backup
  83           0         1          0  0.00%  0.00%  0.00%   0 RTTYC Flush
 160           0         1          0  0.00%  0.00%  0.00%   0 HRPC span reques
 161           0         1          0  0.00%  0.00%  0.00%   0 HRPC obfl reques
 162          17        63        269  0.00%  0.00%  0.00%   0 HRPC system post
 163          25        25       1000  0.00%  0.00%  0.00%   0 Hulc Reload Mana
 164           8        80        100  0.00%  0.00%  0.00%   0 HRPC hrcli-event
 165       26905     21811       1233  0.00%  0.00%  0.00%   0 HRPC rfs request
  84         478      2192        218  0.00%  0.00%  0.00%   0 Hulc Port-Securi
 167       50860  10798279          4  0.00%  0.00%  0.00%   0 Power RPS Proces
  85        2003     20399         98  0.00%  0.00%  0.00%   0 HRPC hpsecure re
 169          24        18       1333  0.00%  0.00%  0.00%   0 HL2MCM
  86      157094    696496        225  0.00%  0.00%  0.00%   0 HRPC hlfm reques
 112           0         1          0  0.00%  0.00%  0.00%   0 hpm vp events ca
 172       18952    541193         35  0.00%  0.00%  0.00%   0 MMN bkgrd proces
 173         192      6148         31  0.00%  0.00%  0.00%   0 Auth Manager
 174           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
 175           0         1          0  0.00%  0.00%  0.00%   0 MAB Framework
 176           0         1          0  0.00%  0.00%  0.00%   0 AUTH POLICY Fram
 177           0         1          0  0.00%  0.00%  0.00%   0 CMD HANDLER
 178        1167      6162        189  0.00%  0.00%  0.00%   0 802.1x switch
 179       25004    541195         46  0.00%  0.00%  0.00%   0 802.1x MDA Aging
 180           0         1          0  0.00%  0.00%  0.00%   0 802.1x Webauth F
 181      366276   2213645        165  0.00%  0.00%  0.00%   0 DTP Protocol
 182           0         1          0  0.00%  0.00%  0.00%   0 EAP Framework
 183           0         1          0  0.00%  0.00%  0.00%   0 EAP Test
 184           0         1          0  0.00%  0.00%  0.00%   0 HRPC dai request
 185           0         1          0  0.00%  0.00%  0.00%   0 HULC DAI Process
 186           0         1          0  0.00%  0.00%  0.00%   0 HRPC ip device t
 187           0         1          0  0.00%  0.00%  0.00%   0 HRPC ip source g
 188           0         1          0  0.00%  0.00%  0.00%   0 HULC IP Source g
 189      346181  32488545         10  0.00%  0.00%  0.00%   0 UDLD
 190        2331   1082952          2  0.00%  0.00%  0.00%   0 Port-Security
 191           0         2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
 192           0         1          0  0.00%  0.00%  0.00%   0 Link State Group
 193       97603   3226196         30  0.00%  0.00%  0.00%   0 Ethchnl
 194        1551      1194       1298  0.00%  0.00%  0.00%   0 VMATM Callback
 195           0         2          0  0.00%  0.00%  0.00%   0 CDP Forward Proc
 196      595836 321015593          1  0.00%  0.00%  0.00%   0 MDFS MFIB Proces
 197           9         2       4500  0.00%  0.00%  0.00%   0 MKA
 198         235      2964         79  0.00%  0.00%  0.00%   0 AAA Server
 199         158      1645         96  0.00%  0.00%  0.00%   0 AAA ACCT Proc
 200           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
 201           0         1          0  0.00%  0.00%  0.00%   0 AAA System Acct
 202           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
 203         394    108295          3  0.00%  0.00%  0.00%   0 IP Admin SM Proc
 204    32395513  40403923        801  0.00%  0.08%  0.07%   0 CDP Protocol
 205          50        70        714  0.00%  0.00%  0.00%   0 Collection proce
 206         851      4694        181  0.00%  0.00%  0.00%   0 HRPC hl2mcm igmp
 207           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
 208        1229    270738          4  0.00%  0.00%  0.00%   0 DHCP Snooping
 209           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
 210           0         3          0  0.00%  0.00%  0.00%   0 CEF switching ba
 211     9165208  82862034        110  0.00%  0.03%  0.00%   0 IP Input
 212           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
 213      127478  62392808          2  0.00%  0.00%  0.00%   0 IP ARP Track
 214           0        17          0  0.00%  0.00%  0.00%   0 ADJ resolve proc
 215           0         3          0  0.00%  0.00%  0.00%   0 ADJ NSF process
 216           0         1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
 217           0         1          0  0.00%  0.00%  0.00%   0 EM Action CNS
 218           0         5          0  0.00%  0.00%  0.00%   0 SMI Director DB
 219           0         1          0  0.00%  0.00%  0.00%   0 SMI CDP Update H
 220           0         1          0  0.00%  0.00%  0.00%   0 SMI Backup Proce
 221           0         2          0  0.00%  0.00%  0.00%   0 SMI IBC server p
 222           0         1          0  0.00%  0.00%  0.00%   0 SMI IBC client p
 223           0         2          0  0.00%  0.00%  0.00%   0 SMI IBC Download
 117      182970  21370114          8  0.00%  0.00%  0.00%   0 hl3mm
 225         667    541449          1  0.00%  0.00%  0.00%   0 Spanning Tree St
 226           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
 227          18       109        165  0.00%  0.00%  0.00%   0 SXP CORE
 228      162358    651676        249  0.00%  0.00%  0.00%   0 CEF background p
 229           0         1          0  0.00%  0.00%  0.00%   0 IP IRDP
 230          34         2      17000  0.00%  0.00%  0.00%   0 CEF RF HULC Conv
 231        2517     17418        144  0.00%  0.00%  0.00%   0 XDR mcast
 232           8        14        571  0.00%  0.00%  0.00%   0 OBFL Cfg Dispatc
 157         686       115       5965  0.00%  0.00%  0.00%   0 HULC SNMP Proces
 235      128798   3227405         39  0.00%  0.00%  0.00%   0 IP ACL XDR LC Ba
 236           0         4          0  0.00%  0.00%  0.00%   0 MDFS LC Process
 237         318     15620         20  0.00%  0.00%  0.00%   0 TCP Timer
 238        1133      1351        838  0.00%  0.00%  0.00%   0 TCP Protocols
 239      100560  33274059          3  0.00%  0.00%  0.00%   0 Socket Timers
 240         466    108401          4  0.00%  0.00%  0.00%   0 HTTP CORE
 241         917    406093          2  0.00%  0.00%  0.00%   0 Cluster L2
 242      173851   3226195         53  0.00%  0.00%  0.00%   0 Cluster RARP
 243       21824   4062016          5  0.00%  0.00%  0.00%   0 Cluster Base
 244           0         2          0  0.00%  0.00%  0.00%   0 CEF LC IPC Backg
 245      168805  39165013          4  0.00%  0.00%  0.00%   0 CEF LC Stats
 246           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
 247           0         1          0  0.00%  0.00%  0.00%   0 Critical Auth
 248           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 249           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 250           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 251           0         4          0  0.00%  0.00%  0.00%   0 HRPC dhcp snoopi
 252           0         7          0  0.00%  0.00%  0.00%   0 HULC DHCP Snoopi
 253           0         1          0  0.00%  0.00%  0.00%   0 HRPC stack power
 254         728      1440        505  0.00%  0.00%  0.00%   0 IGMPSN L2MCM
 255     6765968  58162831        116  0.00%  0.00%  0.00%   0 IGMPSN MRD
 256    53600923 247971190        216  0.00%  0.16%  0.16%   0 IGMPSN
 257           0         1          0  0.00%  0.00%  0.00%   0 IGMPQR
 258           0         3          0  0.00%  0.00%  0.00%   0 L2TRACE SERVER
 259         669      1435        466  0.00%  0.00%  0.00%   0 MLDSN L2MCM
 260           0         1          0  0.00%  0.00%  0.00%   0 MRD
 261           0         1          0  0.00%  0.00%  0.00%   0 MLD_SNOOP
 262     3363323  67951467         49  0.00%  0.01%  0.00%   0 DHCPD Receive
 263           0         1          0  0.00%  0.00%  0.00%   0 HRPC x_setup req
 264       43432    541039         80  0.00%  0.00%  0.00%   0 IP RIB Update
 265          16       249         64  0.00%  0.00%  0.00%   0 HRPC hl2mcm mlds
 266           0        20          0  0.00%  0.00%  0.00%   0 SNMP Timers
 267           0         2          0  0.00%  0.00%  0.00%   0 EPM MAIN PROCESS
 268           0        33          0  0.00%  0.00%  0.00%   0 LOCAL AAA
 269          83       545        152  0.00%  0.00%  0.00%   0 ENABLE AAA
 270           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
 271       18756     11105       1688  0.00%  0.00%  0.00%   0 SNMP Traps
 272       10522     22584        465  0.00%  0.00%  0.00%   0 TPLUS
 273           8        12        666  0.00%  0.00%  0.00%   0 crypto engine pr
 274          25         4       6250  0.00%  0.00%  0.00%   0 Crypto CA
 275           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
 276           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
 277           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
 278           0        41          0  0.00%  0.00%  0.00%   0 VTP Trap Process
 279           0         2          0  0.00%  0.00%  0.00%   0 VTPMIB EDIT BUFF
 280           0         2          0  0.00%  0.00%  0.00%   0 DHCP Security He
 281           0         1          0  0.00%  0.00%  0.00%   0 HCD Process
 282           0         5          0  0.00%  0.00%  0.00%   0 HRPC cable diagn
 283           0         2          0  0.00%  0.00%  0.00%   0 DiagCard2/-1
 284     2400249 556767328          4  0.00%  0.01%  0.00%   0 PM Callback
 285          25        16       1562  0.00%  0.00%  0.00%   0 VLAN Manager
 286           0         1          0  0.00%  0.00%  0.00%   0 DiagCard4/-1
 287        6264   2599981          2  0.00%  0.00%  0.00%   0 dhcp snooping sw
 288           0         1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
 289           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Routing
 290         316     20942         15  0.00%  0.00%  0.00%   0 EEM ED Syslog
 291           0         1          0  0.00%  0.00%  0.00%   0 image mgr
 292         200      1583        126  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
 293       36339     10046       3617  0.00%  0.00%  0.00%   0 Syslog Traps
 294        1494     11046        135  0.00%  0.00%  0.00%   0 Syslog
 295        4313       825       5227  0.00%  0.00%  0.00%   0 SpanTree Helper
 296         137       436        314  0.00%  0.00%  0.00%   0 EEM Server
 297           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
 298        3474     18034        192  0.00%  0.00%  0.00%   0 SSH Event handle
 299           0         2          0  0.00%  0.00%  0.00%   0 EEM ED CLI
 300           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
 301           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
 302           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
 303           0         3          0  0.00%  0.00%  0.00%   0 EEM ED None
 304           0         3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
 305           0         1          0  0.00%  0.00%  0.00%   0 DiagCard3/-1
 306           0         6          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
 307           0         3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
 308           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Ipsla
 309           0         2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
 310        6982    939301          7  0.00%  0.00%  0.00%   0 EEM ED Timer
 311           0         2          0  0.00%  0.00%  0.00%   0 STP FAST TRANSIT
 312          82      1602         51  0.00%  0.00%  0.00%   0 CSRT RAPID TRANS
 313           0         3          0  0.00%  0.00%  0.00%   0 RBM CORE
 314    15452081    873675      17686  0.00%  0.00%  0.00%   0 crypto sw pk pro
 166           0         1          0  0.00%  0.00%  0.00%   0 HRFS OIR Proc
 316         200       638        313  0.00%  0.00%  0.00%   0 SpanTree Flush
 317           0         1          0  0.00%  0.00%  0.00%   0 DiagCard1/-1
 318           0         1          0  0.00%  0.00%  0.00%   0 Connection Mgr
 319         889    279745          3  0.00%  0.00%  0.00%   0 DHCPD Timer
 320       15192    541196         28  0.00%  0.00%  0.00%   0 DHCPD Database
 321           0         1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
 322       14624   2164634          6  0.00%  0.00%  0.00%   0 MDFS LC Download
 323     4050002  15005407        269  0.00%  0.00%  0.00%   0 IP SNMP
 324     2368639   7407993        319  0.00%  0.00%  0.00%   0 PDU DISPATCHER
 325    71933335  29059939       2475  0.00%  0.00%  0.00%   0 SNMP ENGINE
 326           0         2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
 327           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
 328      142064  32753263          4  0.00%  0.00%  0.00%   0 NTP
 329     1714687 327438225          5  0.00%  0.00%  0.00%   0 MDFS RP process
 330         149       135       1103  0.00%  0.00%  0.00%   0 hulc cfg mgr mas
 331      260212      1379     188696  0.00% 12.64%  4.50%   0 hulc running con
 332           0         1          0  0.00%  0.00%  0.00%   0 RTTYS Process
 171           0         3          0  0.00%  0.00%  0.00%   0 Switch Backup In
 334       19497    541016         36  0.00%  0.00%  0.00%   0 802.1x MDA Aging
 337        4718    180433         26  0.00%  0.00%  0.00%   0 HCMP sync proces
 338           0         2          0  0.00%  0.00%  0.00%   0 hulc_tb_process
 339     2415904   9842050        245  0.00%  0.01%  0.00%   0 IPC LC Message H
 340           0         4          0  0.00%  0.00%  0.00%   0 XDR RP Ping Back
 341        4567    270896         16  0.00%  0.00%  0.00%   0 XDR RP backgroun
 342           0         1          0  0.00%  0.00%  0.00%   0 XDR RP Test Back
 343           0         7          0  0.00%  0.00%  0.00%   0 CEF RP IPC Backg
Please find more EEM output
CPU utilization for five seconds: 72%/1%; one minute: 20%; five minutes: 13%
 325    71942425  29061721       2475 53.18%  8.25%  1.83%   0 SNMP ENGINE
 149    70334613 922183020         76  3.98%  0.79%  0.31%   0 Hulc LED Process
  93   209189468   3227049      64824  3.02%  0.70%  0.60%   0 HULC Tcam Memory
  71   1093435341690591985         64  2.06%  0.71%  0.41%   0 Fifo Error Detec
 110   291975112  66878504       4365  0.95%  0.86%  0.85%   0 hpm counter proc
 168    81777686 292066101        279  0.63%  0.25%  0.26%   0 HL2MCM
 158   124763719   6454160      19330  0.47%  0.35%  0.36%   0 HQM Stack Proces
 224    42202897 212601403        198  0.31%  0.08%  0.08%   0 Spanning Tree
 159   106423401  51600833       2062  0.31%  0.24%  0.21%   0 HRPC qos request
 106    13220026 370664106         35  0.31%  0.07%  0.01%   0 hpm main process
 262     3364322  67969552         49  0.15%  0.01%  0.00%   0 DHCPD Receive
  65    52065771 720246777         72  0.15%  0.19%  0.18%   0 RedEarth Tx Mana
 211     9167389  82882822        110  0.15%  0.15%  0.04%   0 IP Input
  31    21262514   3938892       5398  0.15%  0.07%  0.05%   0 Net Background
  35     3271220  32329547        101  0.15%  0.02%  0.00%   0 Per-Second Jobs
  75    30667151 134022347        228  0.15%  0.38%  0.14%   0 hrpc <- response
  66     53952131261367847          4  0.15%  0.02%  0.00%   0 RedEarth Rx Mana
 118       63844  16135251          3  0.15%  0.01%  0.00%   0 hl3mm_rp
 323     4050227  15006221        269  0.15%  0.22%  0.05%   0 IP SNMP
 189      346264  32497199         10  0.15%  0.01%  0.00%   0 UDLD
 329     1715198 327525422          5  0.15%  0.04%  0.00%   0 MDFS RP process
  21      476092   8656305         54  0.00%  0.00%  0.00%   0 IPC Seat Manager
  20       91963  32261597          2  0.00%  0.00%  0.00%   0 IPC Deferred Por
  18      110772  32261594          3  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  28       91050  32261466          2  0.00%  0.00%  0.00%   0 GraphIt
  16       16573    541341         30  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  24      117890  32261592          3  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  34      103038  32261458          3  0.00%  0.00%  0.00%   0 TTY Background
  40    25039972   6679622       3748  0.00%  0.06%  0.05%   0 Compute load avg
  42          35      5316          6  0.00%  0.00%  0.00%   0 Transport Port A
  45      694165 640463898          1  0.00%  0.00%  0.00%   0 DownWhenLooped
  33        3419     19356        176  0.00%  0.00%  0.00%   0 Logger
  36    14379445    553822      25964  0.00%  0.03%  0.00%   0 Per-minute Jobs
  60      190413   1225261        155  0.00%  0.00%  0.00%   0 EEM ED ND
  63      111911   6454104         17  0.00%  0.00%  0.00%   0 Hulc LED Alchemy
  43     2892937   6960508        415  0.00%  0.01%  0.00%   0 HC Counter Timer
  67        2311    216633         10  0.00%  0.00%  0.00%   0 HULC Thermal Pro
  73     1542536  32261482         47  0.00%  0.00%  0.00%   0 hrpc -> response
  74     1646436  69466039         23  0.00%  0.00%  0.00%   0 hrpc -> request
  78       10447     30047        347  0.00%  0.00%  0.00%   0 HRPC hdm non blo
   9       67025    599159        111  0.00%  0.00%  0.00%   0 ARP Input
  86      157119    696649        225  0.00%  0.00%  0.00%   0 HRPC hlfm reques
  88      133411  32261466          4  0.00%  0.00%  0.00%   0 HLFM aging proce
  89     3110261 949082564          3  0.00%  0.00%  0.00%   0 HLFM address ret
  92      267066    852763        313  0.00%  0.00%  0.00%   0 HRPC hulc misc r
  94       71237  10801159          6  0.00%  0.00%  0.00%   0 HVLAN main bkgrd
  97       34965    206313        169  0.00%  0.00%  0.00%   0 HRPC vlan reques
  99       30462    541338         56  0.00%  0.00%  0.00%   0 hulc_xps_process
 111    46275542 207724060        222  0.00%  0.13%  0.12%   0 HRPC pm-counters
 114          32     15476          2  0.00%  0.00%  0.00%   0 HCEF ADJ Refresh
 117      183004  21375807          8  0.00%  0.00%  0.00%   0 hl3mm
  87    12716516 948952078         13  0.00%  0.03%  0.00%   0 HLFM address lea
   5       29320    892811         32  0.00%  0.00%  0.00%   0 Pool Manager
 135     3266739 160267739         20  0.00%  0.00%  0.00%   0 Hulc Storm Contr
   4   313471552  14477254      21652  0.00%  0.93%  0.91%   0 Check heaps
 150      877489  23656414         37  0.00%  0.00%  0.00%   0 HL3U bkgrd proce
 151     3374415  38698078         87  0.00%  0.00%  0.00%   0 HRPC hl3u reques
 152       25962   7418583          3  0.00%  0.00%  0.00%   0 HL3U PBR bkgrd p
 153        1180    270792          4  0.00%  0.00%  0.00%   0 HL3U PBR n-h res
   3     1984832  49726053         39  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
   2      122589   6488159         18  0.00%  0.00%  0.00%   0 Load Meter
  81      124588   6454106         19  0.00%  0.00%  0.00%   0 HIPC bkgrd proce
 167       50868  10801155          4  0.00%  0.00%  0.00%   0 Power RPS Proces
  95      249189    557263        447  0.00%  0.00%  0.00%   0 IP Background
 172       18960    541337         35  0.00%  0.00%  0.00%   0 MMN bkgrd proces
 179       25021    541339         46  0.00%  0.00%  0.00%   0 802.1x MDA Aging
 181      366325   2214225        165  0.00%  0.00%  0.00%   0 DTP Protocol
   1      101471   1614058         62  0.00%  0.00%  0.00%   0 Chunk Manager
 190        2331   1083241          2  0.00%  0.00%  0.00%   0 Port-Security
 193       97612   3227055         30  0.00%  0.00%  0.00%   0 Ethchnl
 196      595986 321101059          1  0.00%  0.00%  0.00%   0 MDFS MFIB Proces
 203         394    108323          3  0.00%  0.00%  0.00%   0 IP Admin SM Proc
 204    32404554  40417073        801  0.00%  0.09%  0.10%   0 CDP Protocol
 208        1247    270811          4  0.00%  0.00%  0.00%   0 DHCP Snooping
 213      127495  62409421          2  0.00%  0.00%  0.00%   0 IP ARP Track
 225         667    541593          1  0.00%  0.00%  0.00%   0 Spanning Tree St
 227          18       110        163  0.00%  0.00%  0.00%   0 SXP CORE
 228      162382    651849        249  0.00%  0.00%  0.00%   0 CEF background p
 233          34         9       3777  0.00%  0.00%  0.00%   0 EEM Callback Thr
 234         134       131       1022  0.00%  0.00%  0.00%   1 Virtual Exec
 235      128857   3228265         39  0.00%  0.00%  0.00%   0 IP ACL XDR LC Ba
 237         334     16052         20  0.00%  0.00%  0.00%   0 TCP Timer
 239      100612  33282916          3  0.00%  0.00%  0.00%   0 Socket Timers
 240         466    108429          4  0.00%  0.00%  0.00%   0 HTTP CORE
 241         917    406201          2  0.00%  0.00%  0.00%   0 Cluster L2
 242      173885   3227054         53  0.00%  0.00%  0.00%   0 Cluster RARP
 243       21824   4063098          5  0.00%  0.00%  0.00%   0 Cluster Base
 245      168863  39175440          4  0.00%  0.00%  0.00%   0 CEF LC Stats
 255     6769023  58190305        116  0.00%  0.03%  0.00%   0 IGMPSN MRD
 256    53618406 248052112        216  0.00%  0.12%  0.16%   0 IGMPSN
 264       43448    541183         80  0.00%  0.00%  0.00%   0 IP RIB Update
 284     2400870 556908702          4  0.00%  0.00%  0.00%   0 PM Callback
 287        6264   2600673          2  0.00%  0.00%  0.00%   0 dhcp snooping sw
 294        1494     11047        135  0.00%  0.00%  0.00%   0 Syslog
 296         137       449        305  0.00%  0.00%  0.00%   0 EEM Server
 298        3474     18040        192  0.00%  0.00%  0.00%   0 SSH Event handle
 306         360      2582        139  0.00%  0.00%  0.00%   0 EEM ED SNMP
 310        6982    939565          7  0.00%  0.00%  0.00%   0 EEM ED Timer
 314    15457835    874002      17686  0.00%  0.00%  0.00%   0 crypto sw pk pro
 319         889    279819          3  0.00%  0.00%  0.00%   0 DHCPD Timer
 320       15192    541340         28  0.00%  0.00%  0.00%   0 DHCPD Database
 322       14642   2165210          6  0.00%  0.00%  0.00%   0 MDFS LC Download
 324     2368689   7408400        319  0.00%  0.03%  0.00%   0 PDU DISPATCHER
 328      142133  32762050          4  0.00%  0.00%  0.00%   0 NTP
 170     2324992  32261463         72  0.00%  0.02%  0.00%   0 PI MATM Aging Pr
 331      260212      1379     188696  0.00%  0.00%  0.00%   0 hulc running con
 334       19497    541160         36  0.00%  0.00%  0.00%   0 802.1x MDA Aging
 337        4718    180481         26  0.00%  0.00%  0.00%   0 HCMP sync proces
 339     2416579   9844669        245  0.00%  0.00%  0.00%   0 IPC LC Message H
 341        4576    270968         16  0.00%  0.00%  0.00%   0 XDR RP backgroun
14:58:45.422 UTC Sun Jul 13 2014
CPU utilization for five seconds: 81%/0%; one minute: 21%; five minutes: 13%
 325    71954590  29063029       2475 56.31%  8.62%  1.87%   0 SNMP ENGINE
 149    70365005 922590436         76  5.75%  0.91%  0.32%   0 Hulc LED Process
  93   209282090   3228477      64824  3.35%  0.71%  0.61%   0 HULC Tcam Memory
  71   1093966061691340293         64  1.75%  0.60%  0.39%   0 Fifo Error Detec
   4   313611314  14483676      21652  1.43%  1.04%  0.93%   0 Check heaps
 204    32420529  40437641        801  1.27%  0.14%  0.07%   0 CDP Protocol
 110   292104316  66908096       4365  0.79%  0.89%  0.85%   0 hpm counter proc
  36    14385841    554067      25964  0.63%  0.07%  0.01%   0 Per-minute Jobs
  75    30678290 134074322        228  0.63%  0.36%  0.13%   0 hrpc <- response
 224    42221244 212687841        198  0.47%  0.13%  0.11%   0 Spanning Tree
 111    46293754 207815887        222  0.47%  0.14%  0.11%   0 HRPC pm-counters
 158   124818988   6457016      19330  0.47%  0.36%  0.36%   0 HQM Stack Proces
  65    52094188 720582708         72  0.31%  0.15%  0.16%   0 RedEarth Tx Mana
  35     3272331  32343859        101  0.31%  0.02%  0.00%   0 Per-Second Jobs
 284     2401894 557156839          4  0.15%  0.01%  0.00%   0 PM Callback
  87    12722467 949371888         13  0.15%  0.03%  0.00%   0 HLFM address lea
 159   106475866  51623681       2062  0.15%  0.42%  0.43%   0 HRPC qos request
 329     1716057 327670421          5  0.15%  0.03%  0.00%   0 MDFS RP process
 323     4050598  15007641        269  0.15%  0.28%  0.06%   0 IP SNMP
 196      596257 321243172          1  0.15%  0.01%  0.00%   0 MDFS MFIB Proces
  40    25051571   6682478       3748  0.15%  0.06%  0.06%   0 Compute load avg
  31    21272435   3941092       5397  0.15%  0.05%  0.05%   0 Net Background
 262     3365891  67999629         49  0.15%  0.01%  0.00%   0 DHCPD Receive
  21      476260   8660138         54  0.00%  0.00%  0.00%   0 IPC Seat Manager
  20       91963  32275874          2  0.00%  0.00%  0.00%   0 IPC Deferred Por
  24      117939  32275869          3  0.00%  0.01%  0.00%   0 Dynamic ARP Insp
  28       91067  32275743          2  0.00%  0.00%  0.00%   0 GraphIt
  18      110822  32275871          3  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  43     2894015   6963595        415  0.00%  0.00%  0.00%   0 HC Counter Timer
  45      694425 640747340          1  0.00%  0.00%  0.00%   0 DownWhenLooped
  33        3462     19721        175  0.00%  0.00%  0.00%   0 Logger
  34      103095  32275735          3  0.00%  0.00%  0.00%   0 TTY Background
  38         239     11186         21  0.00%  0.00%  0.00%   0 IF-MGR event pro
  60      190531   1226172        155  0.00%  0.00%  0.00%   0 EEM ED ND
  63      111970   6456960         17  0.00%  0.00%  0.00%   0 Hulc LED Alchemy
  66     53976551261925972          4  0.00%  0.00%  0.00%   0 RedEarth Rx Mana
  67        2320    216729         10  0.00%  0.00%  0.00%   0 HULC Thermal Pro
  73     1543201  32275759         47  0.00%  0.00%  0.00%   0 hrpc -> response
  74     1647064  69492547         23  0.00%  0.00%  0.00%   0 hrpc -> request
  78       10455     30071        347  0.00%  0.00%  0.00%   0 HRPC hdm non blo
   9       67328    599587        112  0.00%  0.00%  0.00%   0 ARP Input
  86      157272    697369        225  0.00%  0.00%  0.00%   0 HRPC hlfm reques
  88      133444  32275743          4  0.00%  0.00%  0.00%   0 HLFM aging proce
  89     3111529 949502426          3  0.00%  0.01%  0.00%   0 HLFM address ret
  92      267066    852795        313  0.00%  0.00%  0.00%   0 HRPC hulc misc r
  94       71255  10805941          6  0.00%  0.00%  0.00%   0 HVLAN main bkgrd
  95      249482    557783        447  0.00%  0.00%  0.00%   0 IP Background
  99       30479    541578         56  0.00%  0.00%  0.00%   0 hulc_xps_process
 106    13225682 370827741         35  0.00%  0.03%  0.01%   0 hpm main process
 108       20474     76714        266  0.00%  0.00%  0.00%   0 HRPC pm request
   5       29320    893213         32  0.00%  0.00%  0.00%   0 Pool Manager
 114          32     15483          2  0.00%  0.00%  0.00%   0 HCEF ADJ Refresh
 117      183095  21385260          8  0.00%  0.00%  0.00%   0 hl3mm
 118       63906  16142391          3  0.00%  0.00%  0.00%   0 hl3mm_rp
 126        4676     39864        117  0.00%  0.00%  0.00%   0 HRPC dot1x reque
 128        3475     22413        155  0.00%  0.00%  0.00%   0 HULC DOT1X Proce
   3     1985674  49748077         39  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
 135     3268222 160338663         20  0.00%  0.01%  0.00%   0 Hulc Storm Contr
  16       16573    541581         30  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
   2      122646   6491031         18  0.00%  0.00%  0.00%   0 Load Meter
 150      877968  23666881         37  0.00%  0.00%  0.00%   0 HL3U bkgrd proce
 151     3375543  38715193         87  0.00%  0.00%  0.00%   0 HRPC hl3u reques
 152       25970   7421871          3  0.00%  0.00%  0.00%   0 HL3U PBR bkgrd p
 153        1188    270912          4  0.00%  0.00%  0.00%   0 HL3U PBR n-h res
   1      101670   1616162         62  0.00%  0.00%  0.00%   0 Chunk Manager
  81      124624   6456962         19  0.00%  0.00%  0.00%   0 HIPC bkgrd proce
  85        2030     20798         97  0.00%  0.00%  0.00%   0 HRPC hpsecure re
 167       50885  10805937          4  0.00%  0.00%  0.00%   0 Power RPS Proces
 168    81813846 292193365        279  0.00%  0.21%  0.20%   0 HL2MCM
 172       18960    541577         35  0.00%  0.00%  0.00%   0 MMN bkgrd proces
 173         192      6248         30  0.00%  0.00%  0.00%   0 Auth Manager
 178        1175      6262        187  0.00%  0.00%  0.00%   0 802.1x switch
 179       25021    541579         46  0.00%  0.00%  0.00%   0 802.1x MDA Aging
 181      366481   2215192        165  0.00%  0.00%  0.00%   0 DTP Protocol
 189      346456  32511580         10  0.00%  0.00%  0.00%   0 UDLD
 190        2339   1083720          2  0.00%  0.00%  0.00%   0 Port-Security
 193       97705   3228483         30  0.00%  0.00%  0.00%   0 Ethchnl
 203         394    108371          3  0.00%  0.00%  0.00%   0 IP Admin SM Proc
 208        1247    270930          4  0.00%  0.00%  0.00%   0 DHCP Snooping
 211     9170668  82916814        110  0.00%  0.06%  0.01%   0 IP Input
 213      127528  62437038          2  0.00%  0.00%  0.00%   0 IP ARP Track
 225         667    541833          1  0.00%  0.00%  0.00%   0 Spanning Tree St
 228      162442    652137        249  0.00%  0.00%  0.00%   0 CEF background p
 231        2552     17690        144  0.00%  0.00%  0.00%   0 XDR mcast
 233          36         9       4000  0.00%  0.00%  0.00%   0 EEM Callback Thr
 234         158       131       1206  0.00%  0.00%  0.00%   1 Virtual Exec
 235      128933   3229695         39  0.00%  0.00%  0.00%   0 IP ACL XDR LC Ba
 239      100661  33297644          3  0.00%  0.00%  0.00%   0 Socket Timers
 240         466    108477          4  0.00%  0.00%  0.00%   0 HTTP CORE
 241         917    406381          2  0.00%  0.00%  0.00%   0 Cluster L2
 242      173986   3228482         53  0.00%  0.00%  0.00%   0 Cluster RARP
 243       21832   4064895          5  0.00%  0.00%  0.00%   0 Cluster Base
 245      168929  39192775          4  0.00%  0.00%  0.00%   0 CEF LC Stats
 255     6774216  58236088        116  0.00%  0.04%  0.01%   0 IGMPSN MRD
 256    53646337 248186647        216  0.00%  0.16%  0.19%   0 IGMPSN
 264       43456    541423         80  0.00%  0.00%  0.00%   0 IP RIB Update
 271       19072     11305       1687  0.00%  0.00%  0.00%   0 SNMP Traps
 287        6264   2601823          2  0.00%  0.00%  0.00%   0 dhcp snooping sw
 290         316     21322         14  0.00%  0.00%  0.00%   0 EEM ED Syslog
 293       36914     10227       3609  0.00%  0.00%  0.00%   0 Syslog Traps
 294        1536     11252        136  0.00%  0.00%  0.00%   0 Syslog
 296         137       455        301  0.00%  0.00%  0.00%   0 EEM Server
 298        3474     18048        192  0.00%  0.00%  0.00%   0 SSH Event handle
 306        1119      6860        163  0.00%  0.00%  0.00%   0 EEM ED SNMP
 310        6982    939996          7  0.00%  0.00%  0.00%   0 EEM ED Timer
 314    15464446    874377      17686  0.00%  0.00%  0.00%   0 crypto sw pk pro
 319         889    279943          3  0.00%  0.00%  0.00%   0 DHCPD Timer
 320       15192    541580         28  0.00%  0.00%  0.00%   0 DHCPD Database
 322       14642   2166168          6  0.00%  0.00%  0.00%   0 MDFS LC Download
 324     2368838   7408898        319  0.00%  0.06%  0.01%   0 PDU DISPATCHER
 328      142192  32776571          4  0.00%  0.00%  0.00%   0 NTP
 170     2325961  32275740         72  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
 334       19505    541400         36  0.00%  0.00%  0.00%   0 802.1x MDA Aging
 337        4735    180561         26  0.00%  0.00%  0.00%   0 HCMP sync proces
 339     2417420   9849019        245  0.00%  0.00%  0.00%   0 IPC LC Message H
 341        4576    271087         16  0.00%  0.00%  0.00%   0 XDR RP backgroun
18:59:01.162 UTC Sun Jul 13 2014
It took time, but now it is
It took time, but now it is easier to see reason for High CPU. Seems max CPU is taken by :
1. Virtual Exec Process
2. SNMP ENGINE  Process
Now to know what brings the SNMP Engine to Spike the CPU, which MIB is responsible when queried, we need the Stack Trace for SNMP ENGINE.
The Current Stack Trace collected is for IP ACL XDR LC Background. I suggested PID : 235 as, the first post has 235 for SNMP ENGINE:
Now it seems you may have configured the script to another device, or this device is rebooted, after which PID's change. Current PID for SNMP ENGINE is 325.
Edit the EEM with this info.
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
Dear Vinod, Thanks for the
Dear Vinod,
Thanks for the prompt response.
My current eem script is the below (as per your first post)
 event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op gt entry-val "70" exit-op lt exit-val "70" poll-interval 5
 action 1.3 cli command "show clock | append flash:cpu_stats"
 action 1.4 cli command "show stack 235 | append flash:cpu_stats"
 action 1.5 cli command "show proc cpu sort | append flash:cpu_stats"
end
Also the device up-time on show version is more than 1 year so we can assume no reboot happened. Can you please suggest what modification I need to do on EEM.Because currently we are polling for PID 235 only do i need to change it. Also am attaching the full out put of eem script which I got yesterday. (From this file only I pasted the output)
Nibin Rodrigues
more cpu_stats
357
