Bronze
Cisco LMS 4.0.1 Compliance Templates Example for class map ACL (updated, regex bug)
Hi All,
I hope this is helpful for you:
I had some steep learning curves with configuration compliance templates and want to share it with you.
I mastered conditional (prerequesites) templates recently but it was a little bit more difffcult to get "excluding" expressions to work.
In regex it's called "negative lookahead" and will match anything *except* your string.
Task is simple: an ACL for a class map (used for QoS) should contain *only* two specific lines which are mandatory, all other lines should be removed.
Compliance Template is:
Name:  Global   SubMode:  No   isPrerequisite:  No  Ordered :  No
Prerequisite-Commandset :  none  Parent:   none
+ip access-list extended ACL_VoicePayload
Name: AclVoipPayload   SubMode:  Yes  isPrerequisite:   No    Ordered :   No
Prerequisite-Commandset :   none     Parent:    Global
+permit udp any any range 29100 30099 dscp ef
+permit udp any any range 20000 20499 dscp ef
-[#^(?!permit udp any any range 29100 30099 dscp ef|permit udp any any range 20000 20499 dscp ef|ip access-list extended ACL_VoicePayload)#]
ACL on switch is:
remark test for config compliance templates
Result of Compliance Check is (showing non compliant commands):
Device Details
Device Commands
switch2001    ip access-list extended ACL_VoicePayload
Explanation of the template:
+permit udp any any range 29100 30099 dscp ef  ! Command is required
+permit udp any any range 20000 20499 dscp ef  ! command is required
-[#^(?!permit udp any any range 29100 30099 dscp ef|permit udp any any range 20000 20499 dscp ef|ip access-list extended ACL_VoicePayload).*#]
-       ! this command may not appear in the configuration
[#      ! LMS needs this to encapsulate a regex
^       ! the string should be at the beginning of the line
(?!     ! start a "negative lookahead" group. the following expression should *not* appear,
        ! the vertical bars separate three alternative litaral srtings (for some reason the
        ! negative lookahead is greedy and also captures the name of the access-list itself so
        ! the acl command must be included -looks to me like a bug)
)       ! close the negative lookahead
.*      ! there should be actually any character on the line except our negative lookahead
#]      ! tell LMS the regex is finished
Hope this helps and best regards,
MiKa
Edited by Michael Kafka
Everyone's tags (2)
878
