Cisco LMS - Application very slow
Dear All,
I have installaed Cisco LMS in our data center for LAN equipments management.
When i access my LMS from client PC IE browser, my application is running dead slow.....I doubt its because of the JRE installed in the machines.....
I tried installing Sun Java 2 V 1.3.1 in the Windows XP machine and access the LMS. The application runs very slowly. Then i installed the Sun Java VM in Windows 2000 server machine. Still the same problem. Then i tried installing Microsoft JRE, still the problem persists.
In Cisco LMS document it is mentioned that Microsoft JRE 5.1.3186....But this version is not available in the net.....
Can somebody help me in rectifying this problem?
R. Rajaraman.
Red
Re: Cisco LMS - Application very slow
Which version of LMS are you running? Check your DNS settings.
I have Cisco Works LMS 2.2 with me.....
And I have configured the DNS settings correctly....
I believe it could be the Java problem..... But the thing is i have tried all sorts of combination of JRE in my client machine. Still i'm getting the delay.
regards,
R. Rajaraman.
Hai rajaraman,
I experienced these kind of problems in LMS 2.2
try out the following steps:
1.Check whether you have the java version 1.4.2_04. This is the only version which supports LMS 2.2 , i faced lot of problems if i install latest version of java or lesser verion of java.
2. Then got to your browser and clear the cache from selecting the Sun java console.
3. Initially it will take some time(topology services) to unjar the compressed files, later it will cache and it will be fast.
After finishing this let me know how it performs
Hi there,
I have seen this problem twice. One of them is due to a wrong configuration when we changed the server's IP address. I can't remember the exact steps that we did to resolve it, a Cisco TAC engineer guided me at the time.
The second one is due to high CPU utilization of the server, which could mean you need to upgrade your hardware.
Hope it helps.
592
