Hi ,
DFM performs the following actions:
1. As soon as DFM receives a Link Down Trap from a physical port or interface (or a Warm Start/Cold Start Trap from a system), DFM begins counting the traps.
2. When DFM receives two or more traps within 30 seconds, it considers the network adapter or system to be at fault and DFM generates a Repeated Restarts event or a Flapping event.
The minimum traps parameter is set by the Link trap threshold or Restart trap threshold and the minimum seconds parameter is set by the Link trap window or restart trap window. DFM must receive a minimum of two traps within the trap window in a minimum of 30 seconds before it considers an element at fault.
3. DFM continues to receive traps for 80 seconds after the initial trap, resulting in a stable time of 80 seconds.
The stable time is the amount of time that DFM waits before it clears the Repeated Restarts event or Flapping event.
check this link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_device_fault_manager/3.2/user/guide/Flapping.html#wp1008135
Thanks-
Afroz
[Do rate the useful post]
Thanks-
Afroz
****Ratings Encourages Contributors ****
