Cisco LMS Prime: Device Center does not show Port statistics for Routers
i am wondering why the Port Statistics for Routers are not showing in the Device Center Port Status Section. Is this normal behaviour?
thanks
Alex
Hi Alex,
First of all make sure that DataCollection has been sucessfully ran on this device .if the device is under the datacollection then run the User Tracking again on that device and check the issue.
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroj,
Data Collection as well as Usertracking ran successfully.
regards
Alex
455
