Cisco MIBs
Hi All,
Anyone knows how to get MIBs/OIDs for the following Cisco switches 6513,6509,3560E and 2960.
Thank in advanced.
sams
Re: Cisco MIBs
Go to http://www.cisco.com/go/mibs, and use the MIB Locator to determine which MIBs are supported in your versions of IOS.  From that same interface you will be able to download those MIB files.
Re: Cisco MIBs
I came to that link last time, but i didn't help me. My diffulty was not easy to determine the current IOS version for those switches.
Any other advise?
thanks for your input.
sam
Re: Cisco MIBs
Just run "show version" on the device.  The IOS version and feature set will be seen on the first line of the output.  For example:
IOS (tm) c6sup2_rp Software (c6sup2_rp-JO3SV-M), Version 12.1(23)E4, RELEASE SOFTWARE (fc1)
This switch is running 12.1(23)E4 with the jo3sv feature set (ENTERPRISE/FW W/VIP).
628
