Cisco Network Assistant 3500XL
I have a 3500XL that is running IOS 12.1 sorry i'm not more specific. But CNA won't add this device as a neighbor. Is there a reason? does the switch need any configuration to be accepted? i made sure that http server was running on port 80, but is there anything else?
1 REPLY
Silver
Re: Cisco Network Assistant 3500XL
Hi friend,
hmmm, you are running 12.1 on a 3500XL??
a few days before today i have upgraded my last 3500XL with 12.0(5)WC17.
You should be more precise.
But nevertheless, documentation says all you need is CDP and HTTPS or HTTP enabled.
Did you setup a community and are there less than 40 members?? CNA can only handle 40 devices per community!
Here is a list of supported devices and IOS releases.
http://www.cisco.com/en/US/products/ps5931/prod_release_note09186a00807aea81.html#wp735870
Best regards,
Frank
193
