Cisco Network Assistant - unclear printing
I'm using Cisco Network Assistant 5.4 to manage a couple of LAN switches. When I print a Topology diagram of the Community it is very unclear/blurry. I'm wondering if this is "by design" or if there is something I can do to make the diagram readable?
Thanks heaps,
Ash
Re: Cisco Network Assistant - unclear printing
It is a known problem with no workaround.
Of course if the part which you want to print fits on the screen properly and is readable, you could simply take a screenshot and print that picture without using the CNA printing feature.
Thanks aborole.
Really appreciate your speedy response.
516
