Webcast-Catalyst9k
Cisco Network Assistant
Couldnt make the CNA 3.0 work on cisco 4503 with SE II-plus-TS
cna 3.0 recognizes all other cisco devices like catalyst 2900 but can not connect to 4503 :( do i need to configure something on the 4503?
thanks in advance for your help.
Red
Re: Cisco Network Assistant
CNA uses http to access the devices
Make sure that you do not have the following configured:
no ip http server
If you do, then simply issue the command:
ip http server
Additionally, check the CNA release notes to make sure the device meets minimum IOS requirements for interaction with CNA.
114
