Cisco Network Assistant
Using v. 3.0(1) and cannot access either a 3560G or a 3750 switch. Is this a known problem? Is there a workaround?
JG
Re: Cisco Network Assistant
These devices are supported by Cisco Network Assistant 3.0, check out the following link for the supported devices :
http://www.cisco.com/en/US/products/ps5931/products_data_sheet0900aecd8034fbf1.html
Additionally, make sure that the devices meet the Minimum IOS Requirements to support CNA.
Release Notes for the product are here:
http://www.cisco.com/en/US/partner/products/ps5931/prod_release_note09186a008051d2cf.html
213
