Cisco PI 1.3 upgrade to PI 2.1 and licensing issues
Currently we have installed Cisco PI 1.3 as virtual appliance with evaluation license which is expired. We are planning to upgrade to PI 2.1 but instead of upgrade we are planning to remove old virtual appliance and install new PI 2.1 virtual appliance as there were no licenses installed on old one and its evaluation license expired. But earlier we have purchased this licenses:
R-PI12-K9
Cisco Prime Infrastructure 1.2
R-PI12-BASE-K9
Prime Infrastructure 1.2 Base License and Software
L-PI12-LF-500
Prime Infrastructure 1.2 - Lifecycle - 500 Device Lic
L-PI12-CM-500
Prime Infrastructure 1.2 - Compliance - 500 Device Lic
L-LMS42-CM-500
Prime LMS 4.2 - Compliance - 500 Device Lic PAK
L-PI12-CM-500-LIC
Prime Infrastructure 1.2 - Compliance - 500 Device Lic PAK
L-PI12-LF-500-LIC
Prime Infrastructure 1.2 - Lifecycle - 500 Device Lic PAK
L-PILMS42-500
Prime Infrastructure LMS 4.2 - 500 Device Base Lic
Can I install new PI 2.1 and use that licenses on that PI 2.1 assuming that this licenses were purchased earlier and not used at all.
AFROJ AHMAD
AFAIK ,  yes  you can use them without any issue.
You may need to contact the License team  with UID or VUID details to  re-issue the License for the new HOST or server.
Thanks-
Afroz
**Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Thanks-
Afroz
Thank you
