Cisco Pix 515E Configuration
Is there a way to log which pages are visited by user inside the network ?
By the same way, can I block some site with this pix ?
1 REPLY
Re: Cisco Pix 515E Configuration
Yes, you can.
Just set the right level of logging (debugging) on the pix and you'll be able to check the entire URL on the logs.
And yes you can block it.
With the following command you can filter it but you would need a N2H2 or Websense server too.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a008042d6e9.html#wp1039734
filter
Enable, disable, or view URL, FTP, HTTPS, Java, and ActiveX filtering
[no] filter activex port local_ip mask foreign_ip mask
[no] filter ftp dest-port | except local_ip local_mask foreign_ip foreign_mask [allow]
[interact-block]
[no] filter java port[-port]| except local_ip mask foreign_ip mask
[no] filter https dest-port | except local_ip local_mask foreign_ip foreign_mask [allow]
[no] filter url [http | port[-port]] except local_ip local_mask foreign_ip foreign_mask [allow]
[proxy-block] [longurl-truncate | longurl-deny] [cgi-truncate]
[no] filter url except local_ip local_mask foreign_ip foreign_mask
[no] filter url port | except local_ip mask foreign_ip mask [allow] [proxy-block]
HTH,
rate if it does.
vlad
100
