cisco prime 1.3 issue
filipvanacker
                   I have an issue with cisco prime 1.3 , after a reboot I do not see in design, monitoring configuration any templates or features anymore, where are they gone?
thx
AFROJ AHMAD
Hi ,
I think you move to classic view ..change the view to Lifecycle view .
I have attached the Image for the same.
If that is not the case then show us your scrren shot of what you are missing ?
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
hi, I am in lifecylce mode
Hi ,
If you have not applied this update on PI 1.3 . I would suggest to apply and check the issue then. there are few known issue on PI1.3 :
PI_1_3_0_20-Update.4-16.tar.gz
you can download the same from here:
http://software.cisco.com/download/release.html?mdfid=284652876&flowid=38562&softwareid=284272933&release=1.3.0&relind=AVAILABLE&rellifecycle=&reltype=all
Thanks-
Afroz
that patch is already installed
Cisco Prime Network Control System
Version : 1.3.0.20
Patch: Cisco Prime Network Control System Version: Update.4.16
Patch: Cisco Prime Network Control System Version: Update.3.100.CSCui77571_2
any other ideas, thanks
