Cisco Prime 1.4 and Posture NAC deployment
Hi all,
We have to deploy Posture NAC in a large network and we would like to use Cisco Prime to bulk configurations in switchs.
Has someone deployed this kind of per port config using templates??? We have to configure just some ports(not a range like 12 to 24) and every switch have different vlans in every interface.
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan x
Switch(config-if)# authentication event fail action next-method
Switch(config-if)# authentication event server dead action authorize vlan 10
Switch(config-if)# authentication event server alive action reinitialze
Switch(config-if)# authentication host-mode multi-auth
Switch(config-if)# authentication closed
Switch(config-if)# authentication port-control auto
Switch(config-if)# authentication violation restrict
Switch(config-if)# ip device tracking
Switch(config-if)# dot1x pae authenticator
Switch(config-if)# spanning-tree portfast
Thanks a lot in advance,
  • Network Management
15
