Helo SIRplease help me, I want to add a temperature switch graph to the cacti, how do I do it? how many OIDs do I need to add to the cacti? I use Cisco WS-C2960L-48TS-LL and C9300-48T-4X-E switches, thank you
The content you are looking for has been archived. View related content below.
Hi We are configuring cisco devices via python. and also trying to exploring with API. When using API, there are some connection issues which are not clear yet. So I would like to know what kinds of cisco device can support API. and how can we use AP...
Hi Everyone I am enabling netconf on Cat9k switches and want to use a custom AAA group for it and not just the default. I have the following configuration that works, but want to change it so we use a named group and not the default: aaa new-model ! ...
Dear all,I am configuring a network cfomposed of 4 VLANs with the following devices:- NetGate 6100 Firewall- A Cisco 2951 Router- Ciscon 2960 SwitchVLANs and DHCP were configured on the 2951 router.Note that NAT function is handled by the Firewall.Af...
Hi All!I am currently deploying NAC in my organisation's switches and was wondering if there is a Python script to help ease this task.The commands are almost the same on all the ports, except for the dot1x/mab priority one when there's a device conn...
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Hello!I tested PPTP and L2TP VPN solutions, but considered another solution without the Cisco router involved.I've disabled all the virtual-access and vpdn stuff,sh run all | i vpdnreturns nothing, but the ports for PPTP and L2TP are still open and c...
Hello,i have a pc connected to VPC Peer Switch (vPC2) which has the secondary role. vPC2 builts a vPC with vPC1. How can i configure the port to always keep up the connection for this device, even when peer-link goes down (dragging out the cables).In...
We are running prime with the version 3.10.2 and are not able to edit groups anymore.All the actions are missing on every group. We cannot edit, create or delete groups anymore. This seems to be an issue with chrome (version 117.0.5938.92) as the act...
I cannot edit or duplicate template is Prime Infrastructure anymore.It started many month ago with Chrome.My Workaround was to use Firefox.But with the Update to Firefox 125 the same Issue is now happening here.I guess Chrome and Firefox disabled som...
Trying to add again a CBS switch to our Cisco Business Dashboard setup but keeps failing with verification failure, any help?
Hi everyone, I'm currently working on a project, and I am adding a wireless connection through some LWAPS and the WLC. Each LWAP has a WLAN and a AP group connected so each row of the devices connect to an individual AP. When I created it, every devi...
Hello Everyone,I'm novice to networking. And below is the requirement I'm trying to figure out. Any leads would be greatly appreciated"You are working as an IT architect for a new startup business that grew faster than expected. they expanded to oper...
Hello,The DISA STIG, V-239941, asks that the following be configured:event manager applet BACKUP_CONFIG event syslog pattern "SYSLOG_CONFIG_I" action 1 cli command "copy startup-config scp://userx:xxxxxxx@10.1.48.10//opt/config_backup" action 2 syslo...
I am trying to measure a link speed I have a traffic generator machine.I want my Cisco ASR-1001 to loopback the traffic to the generator,What config do I need to use?I am trying to do it in Layer 3 and there is a switch in between.
Subject | Author | Posted |
04-22-2024 02:28 AM | ||
04-16-2024 04:45 AM | ||
04-16-2024 01:33 AM | ||
04-13-2024 12:00 PM | ||
04-11-2024 05:18 AM |
User | Count |
4 | |
2 | |
1 | |
1 | |
1 |
