Cisco prime 2.0 backup switches and router configuration
We got prime infrastracture 2.0, and we want it each night to backup all our routers and switches configuration, even for switches that we will install later on.
How can we do it?
Thanks alot!!
Omer Shtivi
Hall of Fame Super Silver
Omer,"You can schedule when
Omer,
"You can schedule when Prime Infrastructure collects the configurations of selected devices and specify recurring collections by choosing Operate > Configuration Archives , then clicking Schedule Archive ."
The quote is from the User Guide.
Hope this helps.
Hi Marvin,Thank you for your
Hi Marvin,
Thank you for your response.
When you chose operate-> configuration Archives, and Schedule Archive, you need to choose which components to backup, we want to backup all the network, and if we configure a new switch, we don't want to create another job specally for it, or to delete the current job and create new.
Best regards,
Omer Shtivi
Omer,If you choose no devices
Omer,
If you choose no devices (or choose a group without specifying any devices), the created job will backup all devices (or all devices in the selected group). See screenshot below.
Try that and see if the job updates to include devices devices added after the initial selection.
Could you please let know option on Cisco prime 2.1 to configure NTP IP address, Prime should sync with my Ciso core switch which is configured as NTP master.
Please post your question in
Please post your question in a new thread as it is unrelated to this one.
Hello Marvin,
Hello Marvin,
I tried many times to configure this but i would like the backups to go on a external FTP server. Is that possible ?
I can only access the Backups through the Prime GUI...
Also, is there a way to access the backups through the CLI? When I perform "dir" I see no trace of switches backups...
AL
3045
