Cisco Prime 2.0 - Device Credential Verification Report
Hi PI Experts,
I am confused when I read the Device Credential Verification Report generated by PI. Can you please help?
IP Address / Host   NameReachabilitySNMPReadWriteCLILoginEnableLast Updated At
10.20.0.67Reachablesnmpv2cSuccessFailuretelnetSuccessSuccess2/24/2014 23:13
10.22.216.66Reachablesnmpv2cSuccessSuccesstelnetSuccessSuccess2/25/2014 0:31
10.32.0.3Reachablesnmpv2cSuccessSuccesstelnetSuccessSuccess2/24/2014 15:16
Firstly I am not sure why both CLI Login and Enable show Success even though I did not put in any telnet or ssh credential when I did the device discovery.
Secondly I am not sure why CLI shows telnet while they should be ssh actually.
Cedar
Hi Cedar,
In Prime infrastructure, whenever you are adding/editing the device,  device credential verification will happen automatically as part of  inventory collection and the report can be viewed at Report > Report Launch Pad > Device > Device Credential Verification.
PI is by default showing  the Enabled password as SUCCESS  thogh we have not defined it . could be a BUG. Same on
my PI server
On my serve , I can see both SSH\telnet .  Can you go to Operate > Device work Center >>  select the device and click EDIT. and check what crdentilas are there ?
Ideally you should see Telenet  or SSH whatever is configured on device.
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
I did not use CLI credential to discover all devices.
However, I did go to Device work Center, selected several switches and put in my CLI credential to Update&Sync.
Then I removed my CLI credential afterward.
I would not be surprised if it's another bug as well in PI.
Thanks for the feedback.
Cedar
297
