Webcast-Catalyst9k
Cisco Prime - Configuration > Compliance > Baseline Templates - Regex
it's been very hard for me to find good examples of advanced regular expressions that I may use in my Baseline Template (suggestions of websites would be appreciated):
I need to check if this line exists in my switches:
logging host 10.1.1.2
But old switches have this line (which is perfectly acceptable!)
logging 10.1.12
I have tried, in my baseline template, the following regex:
+[#logging.*10.1.1.2#]
It seemed to work fine, but if the device is NOT compliant, the report says that it will deploy the following command:
That's absurd! I don't want to deploy a regex.
How do I check compliance using regex and then deploy a different command (and not the regext itself)?
1 REPLY
I have this same issue and
I have this same issue and have decided to stick to a single command, so retrofitting all the switches was a necessary evil.  I created a template just for this command (I have multiple destinations) and my template looks like this:
-logging 10.1.1.2
+logging host 10.1.1.2
One thing I have noticed, that if you use the default settings, the template does not see that and will say non-compliant and then re-apply the command.  Example:
+logging facility local7
+logging trap informational
will continue to report non-compliance and re-apply.
425
