Cisco Prime Infraestrutre 2.0 - JOB Not ends
i've a problem in my Cisco prime Infraestructure, i've scheduled a IOS upgrade with a reload in the end, i forgot to permit in the equipment to do reloads from SNMP, and the question is all the job was done except the reload, bu in Jobs dashboard i still seeing that the job is in progress anda i can not abort the process.
Anyone kows ow can i clean this job, from the job list, and why this happens?
Hi , go to administration >
Hi ,
go to administration > Job dashboard
look for the job and delete it from there..
Also I would suggest you to confirgure the below command:
"snmp-server system-shutdown"  command so that PI can reload the device after the software image job.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi, i've alreay added the
i've alreay added the snmp-server command.
With Job i still have problems, qhen i try do abort the job i've the follwing error:
"Selected jobs were not aborted. FAILURE : Exception occured while aborting the job : Job with job id 2752679 does not have any running cancellable tasks.-JOBM_042"
The cancel option isn't enable.
looks like job is already
looks like job is already finished ..
created a new job, it should not be a problem.
Thanks-
Afroz
81
