Cisco Prime Infrastructure 1.2 synchronizaton with active directory
hi all
I have installed Cisco Prime Infrastructure 1.2 and I want to make a synchronization between the PI and the active directory
note:
I want to make that to be able to search about the users on cisco prime infrastructure using Hostname instead of serching on it using IP or MAC address.
how can I do this task ???
thanks all.
I appreciate your support.
1 ACCEPTED SOLUTION
Hi Mohamed,
Integration with AD is not supported in PI
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Mohamed,
Thanks-
Afroz
Thanks alot for your support
211
