Webcast-Catalyst9k
Cisco Prime Infrastructure 1.4 SNMP Traps are not converted into Alarms
Hi everybody,
I just configured SNMP Traps on a Cisco Catalyst 3750-x to send to our Cisco Prime Infrastructure 1.4 Appliance.
Now I forced the Switch to send some traps (Power off a Power Supply, Interface errdisable). The only events I see in Alarms & Events on PI is the same information message everytime:
Configuration management event has been recorded in ccmHistoryEventTable.
I think the forced traps should be converted into alarms? Why can't I see them?
Marc
It seems you're device is
It seems you're device is configured to forward any syslog as snmp trap with following command :
snmp-server enable traps config
You cannot be sure of a snmp trap if it is generated or not, unless you capture it on debug enabled (debug snmp packet).
This message is shown in PI when trap from CISCO-CONFIG-MAN-MIB is sent.
Attached is the list of traps when received by PI and what event is generated.
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Ok, I started debugging as
Ok, I started debugging as you said. I get the following output:
Mar 13 09:28:13.711: SNMP: V2 Trap, reqid 11689, errstat 0, erridx 0
 sysUpTime.0 = 198609846
 snmpTrapOID.0 = ciscoSyslogMIB.2.0.1
 clogHistoryEntry.2.1688 = PM
 clogHistoryEntry.3.1688 = 5
 clogHistoryEntry.4.1688 = ERR_RECOVER
 clogHistoryEntry.5.1688 = Attempting to recover from bpduguard err-disable state on Gi1/0/13
 clogHistoryEntry.6.1688 = 198609844
Mar 13 09:28:13.737: SNMP: Queuing packet to xx.xx.xx.xx
Looks like the Switch is sending SNMP Traps from the ciscoSyslogMIB. Is this why PI can't show the Traps and convert it into a alarm?
After this test I configured logging (syslog) to the PI. Now the errors are showed but still not converted into alarms. I just want to be notified by email when such errors occurs.
Marc
378
