Cisco Prime Infrastructure 2.0: Feature Design Templates that attempt to configure event manager always fail: XDE procedure/java error
Here's a little event manager applet that works when entered manually. It has no interactive components.
event manager environment cell_int 0/0/0
event manager applet check_cellular_down_on_restart
event syslog pattern "SYS-5-RESTART" maxrun 90
action 1.0 wait 75
action 2.0 cli command "enable"
action 3.0 cli command "show cellular $cell_int profile 1 | include Profile 1"
action 4.0 string match "*INACTIVE*" "$_cli_result"
action 5.0 if $_string_result eq 1
action 6.0 syslog priority warnings msg "The cellular interface is down after the router reload"
action 7.0 end
It sends an snmp trap after a reboot based on the status of the cellular0/0/0 interface.
The problem is this: Prime won't execute these commands. This is the error I get:
Error in running XDE Procedure, Error Message::Failed to invoke java string class method :null
This happens while it tries the first line of the template.
Does anyone know why this is? Is it possible to configure event manager applets from Prime?
Everyone's tags (1)
216
