02-20-2014 10:13 AM
Good evening,
I have setup Cisco Prime Infrastructure 2.0 and, though I have added manually my 4 network cores as devices without any problem, I can't get a single trap or a single SNMP information to be pushed into my Cisco Prime Infra.
Here is my SNMP config on my core :
snmp-server user *edited* *edited* v3
snmp-server group *edited* v3 noauth notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F
snmp-server community *edited* RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps flowmon
snmp-server enable traps transceiver all
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps rf
snmp-server enable traps memory
snmp-server enable traps cpu_threshold
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps flex-links status
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps ether-oam
snmp-server enable traps aaa_server
snmp-server enable traps flash insertion removal
snmp-server enable traps l2tc threshold sys-threshold
snmp-server enable traps power-ethernet police
snmp-server enable traps rep
snmp-server enable traps vswitch dual-active vsl
snmp-server enable traps udld link-fail-rpt status-change
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps dot1x auth-fail-vlan guest-vlan no-auth-fail-vlan no-guest-vlan
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps entity-diag boot-up-fail hm-test-recover hm-thresh-reached scheduled-test-fail
snmp-server enable traps port-security
snmp-server enable traps ethernet evc status create delete
snmp-server enable traps energywise
snmp-server enable traps ipsla
snmp-server enable traps vstack
snmp-server enable traps bfd
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps event-manager
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps isis
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps errdisable
snmp-server enable traps ethernet cfm alarm
snmp-server enable traps vlan-membership
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vnet-trunk-down
snmp-server host *ip-address-edited* version 3 noauth *edited*
Basically all traps are enabled but absolutely nothing is showing up in my Prime Infra except that my 4 devices are "Reachable".
Here is a show snmp on the same device :
sh snmp
Chassis: *S/N Edited*
38554534 SNMP packets input
0 Bad SNMP version errors
14 Unknown community name
0 Illegal operation for community name supplied
0 Encoding errors
38453185 Number of requested variables
0 Number of altered variables
17790703 Get-request PDUs
20583581 Get-next PDUs
0 Set-request PDUs
0 Input queue packet drops (Maximum queue size 1000)
38490708 SNMP packets output
0 Too big errors (Maximum packet size 1500)
0 No such name errors
0 Bad values errors
0 General errors
38371069 Response PDUs
13 Trap PDUs
SNMP global trap: enabled
SNMP agent enabled
SNMP logging: enabled
Logging to *edited*, 0/10, 13 sent, 0 dropped.
Can anyone point out what is wrong or missing in my configuration? I can't seem to single it out myself.
Jeremy
02-21-2014 08:47 AM
Hi Jeremy,
SNMP traps are shown in the events and alerts section of PI.
SNMP config looks fine. Can you run the SNMP debug (debug snmp packets ) .check the logs and see if the device is actually sending the TRAPS to the PI server.
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
