03-13-2014 01:26 AM
Dears;
can any one help ? our PI 2.0 is very very slow in response, i click and go do other job until it loads, some time it works fine for a few minutes and then back poor again. this result i can't manage any thing.
03-13-2014 02:39 AM
Did you check the disk space ? :: df -h
Also check /opt/CSCOlumos/conf/messaging.properties , it should have the correct ipaddress,if not edit it and correct the Ip address.
Do you have any backup when it was running fine ? or it is slow since the installtion ?
Thanks-
Afroz
**Ratings Encourages Contributors ***
03-16-2014 03:28 AM
Hello Afrahmad;
could you please provide to show what you mentions.
i issued from console
#show disks
10 % used
view memory from Vcenter
about 40% to 50% free.
#show memory from Console
free a few mega from 12 G assigned.
how this diffrence appears??
03-16-2014 05:33 AM
i assigned new memory [make it 16 G] and the same behavior, a few free megas.
it seems there is a problem in allocating memory and free up memory,, any help ??
03-16-2014 06:58 AM
-Try to reboot the server once.
- From the UI of the PI, please go to Administration > Background Tasks. Are there
usually a large number of tasks there that are in Running or Waiting state? If so deleted or disabled them for a while and see if it makes any differenec in the performance
IMP ***Backing up a large database affects the performance of Prime Infrastructure server.
Schedule backups to run when Prime Infrastructure server is idle (for example, in the middle of the night).
share the output of : df -h command
Show mem
One more thing ,performance also depeneds how your VM is configured
thin or thick provisioning ?
Try to allow some more resources to your VM machine and check the issue.
Thanks-
Afroz
[Do rate the useful post]
***Ratings Encourages Contributors***
03-19-2014 12:56 AM
Hello;
-Try to reboot the server once [i did several times, it the same poor preformance].
usually a large number of tasks there that are in Running or Waiting state? If so deleted or disabled them for a while and see if it makes any differenec in the performance [ i found the tasks idle or succedded, i didn't find any task running, any way i disabled unneeded tasks]
df -h command [sorry, but Where to issue this command]
Show mem
total memory: 16305052 kB
free memory: 333528 kB
cached: 5959544 kB
swap-cached: 519280 kB
be noted that i already increased the memorfu fro 12 G to 16 G and the same low free memory.
the Disk is assigned eagr zerod thick provisioned, i increased the memory from 12G to 16G;
the wiered matter is the memory utilization from vcenter show the cisco prime utilizing only 50 to 60 %,, whe do a show mem on pi it self it show a few megas free as shown in upper section
