Community Member
Cisco Prime Infrastructure 2.1.0.0.87 - VLAN.DAT fetch failure
Hello Fellow Networkers,
I'm encountering Fetch VLAN Configuration failures from a bunch of Cisco 3560 switches (c3560-ipbasek9-mz.122-50.SE3) in a one department.  Whilst the vlan.dat file is deprecated, it still remains important and needs archiving.  From PI I can ssh to the switches in question and the path remains nat free.
Your input would be much appreciated.
Thank you in anticipation.
Michael
Hi Michael,This mean vlan
Hi Michael,
This mean vlan fetch is working for other sites \ devices ?
Is the job status is "partial Successful" for those 3560's ?
check if there is any firewall rule Blocking the TFTP protocol ,if yes allow the TFTP protocol and check the issue again.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Community Member
HI Guys & Gals,I tftp-served
HI Guys & Gals,
I tftp-served out the vlan.dat on the C3560 and was able to copy tftp: disk: on the Prime admin shell console.  This eliminates both the switch and the network from our enquiries.
174
