07-01-2014 01:47 PM
My cisco prime infrastructure performs a switch inventory job every night at 22:00 hrs. When I looked at the syslog of the devices in the inventory, I see some entries that I never saw with other LMS versions.
2014-06-30 22:00:01 Local7.Notice xxx.xxx.xxx.xxx 5410: Jun 30 22:00:00.623 CST: %SYS-5-CONFIG_I: Configured from xxx.xxx.xxx.xxx by snmp
2014-06-30 22:00:01 Local7.Notice xxx.xxx.xxx.xxx 5411: Jun 30 22:00:01.567 CST: %SYS-5-CONFIG_I: Configured from console by vty1 (xxx.xxx.xxx.xxx)
2014-06-30 22:05:10 Local7.Notice xxx.xxx.xxx.xxx 5412: Jun 30 22:05:09.008 CST: %SYS-5-CONFIG_I: Configured from console by vty0 (xxx.xxx.xxx.xxx)
I don't understand what the PI is doing with the switches. Does anyone know what is happening during this inventory background job? TIA
07-01-2014 04:38 PM
Hi ,
This must be happening because of this option:
On PI GUI:
Go to Admin > System Settings > Config Archive page, can you try disabling the option for "Archive Configuration after Inventory Sync"?
I think the check box is checked and which is why as soon as inventory ran , PI start to collect the configuration archive and in that case ,it logged into the device and which is why it is generating the SYS_config syslogs.
Thanks-
Afroz
****Ratings Encourages Contributors ****
07-02-2014 06:47 AM
Thank you for your excellent information. Another question - on my current LMS3.2 installation, I scheduled an Periodic Polling to run everyday at a set time. Can I do the same thing on PI2.1? TIA
07-02-2014 10:27 AM
Hi ,
Go to Operate > Device Work Center >Configuration Archive
click on "scheduled Archive" same as LMS.
Thanks-
Afroz
07-02-2014 10:48 AM
Thanks again. I'm still dont understand the log entries on the switch. Did you see my screenshot? The setting you mentioned is already disabled. TIA
07-02-2014 04:32 PM
check the other backgroud task , see if any thing is related to SSH\Telent which need the PI to login to the device like configuration collection etc.. must be some background task
Thanks-
Afroz
07-02-2014 11:18 PM
Can you disable the "switch inventorytask" from the Admin > Background Tasks and hope that will take care of syslog issue,
Thanks-
Afroz
07-02-2014 06:57 AM
08-26-2014 04:25 AM
Hello all,
we have the same problem maybe; Cisco Prime IF 2.1 is changing the running-configs and produces out-of-syncs ;
it turns so for us is, as if Cisco Prime IF 2.1 a snmp-server host x.x.x.x community entry writes in the running-config,
so are running-and startup-config are out-of-sync; is this correct? Herbert
