Cisco Prime infrastructure mail setting configuration issue
Mohamed Sayed
Hi all,
after I configured the global mail setting on my cisco prime infrastructure (I set the ip of primery SMTP then sender and reciever parameters) then I press on test button to send a test mail but it not send ??
note that:
I made sure all services are running using (ncs status) command
Mohamed Sayed
update 1
the test mail is send correctly.
now I tried to generate a report and configured it to send a pdf file to the same e-mail,
the report is generated but not send to the mail??
how can I solve this ??
