Community Member
Cisco Prime Infrastructure (NCS) planning mode with non-rectangular building
How can I run planning mode in Cisco Prime Infrastructure (maps) with a building that is non-rectangular? It places AP's outside the coverage area. I have also tried excluding the outdoor area on the map.
Adjust the size or placement
Adjust the size or placement of the rectangle by selecting the edge of the rectangle and holding down the Ctrl key. Move the mouse as necessary to outline the targeted location. When you use the next-generation maps mode, the rectangle is resizable by dragging on the handles on its edges and corners.
Community Member
Thank you for your response.
Thank you for your response. The building I am planning for is a U shape with the part in the middle being exterior. We do not want to install outdoor AP's but with the directions you provide I can only change the size of the rectangle, not the shape. Is my only option to remove the access points shown outside?
172
