Community Member
Cisco Prime Infrastructure
Hi every one
sorry for the question. Im just starting with this. is it possible for CPI to have a schedule backup of the switches? like saving the running config on the network or somewhere else?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Babak, Yes ,it is possible
Hi Babak,
Yes ,it is possible.
Operate > Device Work Center > Configuration Archives
click "scheduled Archive:
hope it will help
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Babak,
hope it will help
Thanks-
Afroz
Community Member
Thanks for the replyI changed
I changed the view to classic and couldn't see any thing in there. I change it to newer theme and operate menu appeared
77
