Cisco Prime LMS 4.2 Device Availability Poller & Portlet
The default, non-editable "System" Device Availability poller appears to be the only one used by the Availability Pie Chart Portlet. Or is there a way to a show a chart based on a user defined poller, which excludes devices known to be currently offline?
Everyone's tags (5)
Hi ,
It's true  that you will not be able to Delete the system Defined pollers ,however you can DEACTIVATE them.
selecet system defined device availblity poller and De-activate it..
Now created a NEW poller , add the devices which you are interested in. and you should able to see the data in the PIE chart for the user defined poller.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Afroz
That was the first thing I tried, but it did not want  to work. It must have been finger trouble, although it is a different  system on which it now works.
David
468
