02-25-2014 05:05 AM
A Cisco Prime NCS physical appliance has been shipped with version NCS 1.1
Then it has been upgraded to:
1) ncs_patch-1.1.0.58-upgrade-12.tar.gz
2) PI-upgrade-bundle-1.3.0.20.tar.gz
Our customer have got only 1.2 licenses. How can we downgrade the appliance to 1.2 ?
Or how can we re-install 1.1 or 1.2, for both versions we did not find the iso's to download.
Thanks in advance
Solved! Go to Solution.
02-25-2014 08:46 AM
correct , you can ask the license team to generate the new license for PI 1.3 based on the existing license and other details
PI 1.2 has been removed from CCO.
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
02-25-2014 05:53 AM
What is the Current verison of NCS ,you are using ?
AFAIk, you can Installed PI 1.3 directly as PI 1.2 is not available for download.
Conatct the License Team and they will re-host the license for you.
you can downlaod the iso file from the below link:
Note:Upgrade from Cisco Prime Network Control System 1.1.2.12 or 1.1.3.2 to Cisco Prime Infrastructure 1.3.0.20 is not supported.
Thanks-
Afroz
02-25-2014 08:43 AM
You mean that having a 1.2 license, I can install 1.3 and simply ask for a re-hosting ?
I do easily find the 1.3 software but not the 1.2
Kind Regards
02-25-2014 08:46 AM
Thanks-
Afroz
02-25-2014 11:10 AM
Thank you for all
