Webcast-Catalyst9k
Cisco Prime upgrade 4.0 to 4.1
Hi! I have bought license for LMS 4.0. I want to upgrade to 4.1. Should i buy any additional PAK for the license upgrade?
1 REPLY
Hall of Fame Super Silver
If you have Smartnet Software Application Support (SAS) on your LMS 4.0, the upgrade is available at no cost. Whether or not you have maintenance support, you will need to get a new PAK and license file to apply after (or during) the upgrade. This document lists the SKUs necessary to order.
The procedure is about to complicate a bit more with the imminent release of LMS 4.2. See this guide for additional information.
329
