Cisco View 2811
Dear All,
I have updated Cisco view package as below from Cisco website,
below is my IOS Version, but i could not get the Cisco View of this device,
what could be the problem
Number of Packages Selected for Install : 1
For Product(s) : CiscoView
Install Invoked by user : admin
The Package(s) Selected for Install :
NGMARShare
Successfully installed packages (2):
NGMARShare(1.4) ,Rtr2800(8.0)
Installation Completed for : CiscoView
Cisco IOS Software
, 2800 Software (C2800NM-ADVSECURITYK9-M),
Version 12.4(10c)
Re: Cisco View 2811
Post the list of contents under NMSROOT/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs and NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw.
Re: Cisco View 2811
Dear Clarke,
Post delayed due Boss visit,
what is this NGMARshare, how it can be implemented
Re: Cisco View 2811
Shutdown Daemon Manager, then copy all of the .zip files from NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw to NMSROOT/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs. then restart Daemon Manager, and you should be able to view the 2800.
Re: Cisco View 2811
Dear Clarke,
following error is displayed after doing that copying
Message
Cannot find applicable device package for DEVICE.
This error could be due to one of the following:
- The device package for this device type is not installed.
- Device support for this device type is not available.
- You are trying to open a component inside a device.
To correct the problem, either install a device package for the device type, or open the parent device to manage the component.
Re: Cisco View 2811
Make sure the casusers group has full control over all of the .zip files in both directories.
Re: Cisco View 2811
Dear Clarke,
if u dont mind how can we conclude the above one
Re: Cisco View 2811
As I said previously, make sure the casusers group has full control over all .zip files in both directories. Post the output of:
cacls *.zip
From both directories.
156
