11-14-2011 07:21 PM
I have the next problem:
Now the client need to install the WCS version in the same server of Cisco Work but the installer promts the error "TFTP port 69 needed by WCS is already in use. Please free the port before intalling"
I think the problem was becouse in this server is installed Cisco Works.......
Both softwares must be installed in diferent servers? There are some document with that?
11-14-2011 07:32 PM
You can use "virtual".
11-14-2011 07:34 PM
Hi Leo Laohoo
No virtual licenses for servers........
11-25-2011 10:56 PM
Installing LMS and WCS on the same server is not recommended or supported unless "virtualized". Both software applications make use of some of the same software applications ie Java, Apache, etc. and utilize many of the same TCP/UDP ports that makes coexistence impossible.
Sorry to be the bearer of bad news.
Cary
