Cisco Work VS Cisco Network Assistant
hi guys, i'm wondering wat is the difference btw this 2 product...
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Cisco Work VS Cisco Network Assistant
A good place to start is to look at the respective product data sheets.
CiscoWorks LMS: http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_data_sheet0900aecd803fd8eb.html
CNA: http://www.cisco.com/en/US/products/ps5931/products_data_sheet0900aecd8034fbf1.html
My high level summary is as follows:
CiscoWorks = about $20,000. Manages almost every Cisco switch and router type, provides fault management, configuration management, workflow, path analysis, user tracking, performance monitoring, etc. etc.
CNA = free. Designed for management and configuration assistance for a limited range of Cisco switches and a few routers.
1 REPLY
676
