09-25-2006 11:38 PM
can any body help me regarding , how to crate jitter,http and latency report.
09-26-2006 12:54 AM
What errors are you getting trying to view these reports? Is the ipmaging program still being run out of casuser's crontab?
Note: there were some bugs concerning report generation in IPM 2.3. You should upgrade to IPM 2.3.6 (http://www.cisco.com/cgi-bin/tablebuild.pl/ipm-sol), or for best results, upgrade to LMS 2.6 which includes IPM 2.6.
09-26-2006 01:59 AM
09-26-2006 07:06 AM
Then as I said, try first verifying that ipmaging is still running out of casuser's crontab, then upgrade to IPM 2.3.6, and see if you are able to get report data again.
09-26-2006 11:14 PM
09-27-2006 12:00 PM
As root, run the command:
crontab -e casuser
Verify the ipmaging command is listed.
09-27-2006 09:31 PM
hi ,
My cisco works was installed in window 2000 server.not in solaries.
sravan
09-28-2006 04:33 AM
Then you don't have to worry about crontab. Launch he IPM MSDOS prompt from your start menu, and run the command:
CWB_ipmaging
After that, check to see if your reports contain data. If not, check the output of CWB_ipmaging for errors. In either case, move to IPM 2.3.6, and see if the reports are generated regularly.
09-29-2006 01:42 AM
Hi Thank to iclake,
i had run the command succesfully.Out put of the command is 29the sepember report generated succesfully.So i will wait for 29th september report...
sravan kumar..
