Webcast-Catalyst9k
Cisco Works - 2960 switch ?
does anyone know if Cisco Works LMS 2.5 supports 2660 switches?
1 REPLY
Re: Cisco Works - 2960 switch ?
Hello Vince,
I think you are referring to 2960 Switches. It is supported in LMS 2.5.1 - RME 4.0.3
Please refer the below URL's for details.
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/camp_mgr/camp_4x/cmgr_403/cm40sdt.htm
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/camp_mgr/camp_4x/cmgr_403/index.htm
I hope it helps.
Arul
208
