Cisco Works and PIX 506e
I have 3 PIX firewalls, 2 have almost constant communication with Ciscoworks. Every few minutes, CW thinks the firewall configuration has changed and goes out to get the new config. This happens around the clock. We can't figure out if the problem is in CW or the firewall. Our 3rd firewall is fine. Identical to the other 2 and configured the same way. Help!!!
-Steve
1 ACCEPTED SOLUTION
Re: Cisco Works and PIX 506e
The problem affects all version of PIX OS. The title is misleading since the reason this was broken was to add support for PIS OS 7.x. Prior to when support was added to RME, this problem did not occur.
This is a known bug: CSCsi07492. A workaround script is available by calling the TAC.
That bug looks like the correct answer... only I'm running 6.3(5) and not 7. Is there another one?
-Steve
123
