Cisco Works Detailed Device Report: Bug for 10GB Interfaces - wrong ifSpeed
Cisco Works (3.0: )The Detailed Device Report shows wrong ifSpeed results for 10GB Interfaces. (4.294.967.296 instead of 10.000.000.000)
It's clearly because CW-RME uses the ifSpeed 32Bit-OID instead of 64Bit ifHighSpeed-OIDs. Via snmpget I can see the right ifHighSpeed-results:
(OID=.1.3.6.1.2.1.31.1.1.1.15.4)
Example:
IF-MIB::ifName.4 = STRING: Te1/4
32Bit OID (wrong):
IF-MIB::ifSpeed.4 = Gauge32: 4294967295
64Bit OID (correct MBit/s):
IF-MIB::ifHighSpeed.4 = Gauge32: 10000
The RME-manual tells us, that only "ifSpeed" is used in the Inventory-Schema (IfEntry). Isn't it?
What about the 64Bit-ifHighSpeed OID?
Will there be any bugfix for that?
Re: Cisco Works Detailed Device Report: Bug for 10GB Interfaces
You're absolutely right about everything here. Unfortunately, there is no bug for this yet. I will go ahead and file one, and post the ID.
I have filed CSCsm79917 to track this issue.
711
