Community Member
Cisco Works Discovery Schedule
I had a problem with my schedule jobs.
I have previosly configured (8) eight periodicly schedules but they was stopped. So, when I try to restart it again, this is the answer:
Unable to edit the job 1018.
Refer C:/PROGRA~1/CSCOpx/log/CSDiscovery.log for more details.
There is some way to restart them again?
Thank You. Regards.
Re: Cisco Works Discovery Schedule
How did you try to restart these jobs? What status are they in? What are the errors in the CSDiscovery.log?
please post the output of 'pdshow'. I assume that the discovery job 1018 is still running (or better it hangs).
Could you post a screenshot of
CS > Device and Credential > Device Discovery
showing the "Discovery Summary"
and also of CS > Device and Credentials > Device Discovery > "Discovery Schedule"
Community Member
No, is not running the status is cancelled, =(
Community Member
The jobs status is cancelled because I push stop on every one.
I try to restart this making the selection in "Discovery Schedule panel" and then "edit", then "schedule" but is not allowed to do that.
I tryng to get the logs.
Thank You.
ok, it was running and I think that was the reason why you could not change the settings.
Currently I assume the "Stop Discovery" button works only if the discovery job runs fine and not if discovery hangs. In this situation it was always save to stop and restart dmgtd to stop discovery cleanly.
You could try to restart dmgtd, also to get back the control over this job.
177
